- Joined
- Apr 24, 2022
- Messages
- 2,070
- Likes
- 2,766
I'm still getting it after I leave it on Standby for a period of time. I come back to turn it on, and there is immediate crackling. Reconnecting the USB cable stops it, then it's fine to use. Note that my PC is left on 24/7 so the DAC won't be getting a constant "reboot" like most others, but following what you've said, maybe there is a time delay for this regardless of it being used or not. I'm curious to know if any other users have noticed separate bugs, as this is the only thing "wrong" with mine.OK, I just got the sound bug for the first time even with the latest firmware. Was playing Cyberpunk 2077 and it happened after about one hour of use.
As it's been said it's rather loud but at least it didn't play louder than the volume I used. First time I've had glitches with a Topping DAC. Just paused the game and reconnected to DX5 II (same USB cable) and it works as it always does.
I had the same problem.I'm still getting it after I leave it on Standby for a period of time. I come back to turn it on, and there is immediate crackling. Reconnecting the USB cable stops it, then it's fine to use. Note that my PC is left on 24/7 so the DAC won't be getting a constant "reboot" like most others, but following what you've said, maybe there is a time delay for this regardless of it being used or not. I'm curious to know if any other users have noticed separate bugs, as this is the only thing "wrong" with mine.
I would say the DX1 II is enough for IEMs and small headphones, gaming, office. While the DX5 II is clearly more capable for demanding headphones and suited for enthusiasts. For each his/her own.
DX5-II has over 6x the power output, a colour screen, coax and Bluetooth input, and 12v trigger. I think if you don't need any of that functionality then the DX1-II looks like a winner. I think Topping has done enough to differentiate them and has two great products at amazing price points.
No such issues. I guess the last time I had similar issues was about ten years ago. In that case connecting a device to USB3 lead to noise in audio signal. I solved it by connecting to USB2 instead which only the keyboard and mouse use.True, good points.
Another feature of the DX5ii is the dedicated power supply. I have had bad experiences with some of my USB-powered devices, picking up noise from the USB port.
But that might not be the case with the DX1ii. Can any of the owners confirm this?
Sounds like Topping needs to do a soak test over a longer period of time.
So far the crackling bug only affects USB input? Has anyone been using optical?
True, good points.
Or use Topping HS02 to eliminate ground loop issueYou will always get some USB noise (it varies depending on the setup) if you use the unbalanced RCA output and the devices connected via USB do not have floating ground. Balanced Out and Headphones don't have this issue. You can also solve this by using galvanic isolation (SMSL PO100 to convert USB to Optical, for example).
It doesn't workV2.54 Firmware is out to address these issues
At all? StrangeIt doesn't work
Not really. A few of us (myself included) are experiencing crackling after a period of time. In my case, i've had it after turning the device back on from Standby, while others have had it while in use (read the last couple of pages here). I'm leaving it on Standby this evening then will turn it on in the morning as a test. This is all while using 2.54 (15.54.22.54).At all? Strange
At all? Strange
Should people considering this device be concerned by the fact that they only “optimized” crackling on analog output when switching sample rates on Mac instead of fixing it?
