CuriousAli
- Joined
- Nov 28, 2024
- Messages
- 102
- Likes
- 68
Given there is relatively less info on SSL 12 here, I'm posting my first impressions:
1. Line-in Inputs:
I have used its line-in analog inputs to connect both my turntable and LCD display's audio out (for consoles and Apple TV) and both sound very good, with no noise, no coloration, of course these are my subjective impressions.
2. Headphone Outputs:
It has two headphone outs, while I couldn't find independent measurements, its specs says <1 Ω and it has four settings in its SSL 360 software:
I have the Sony MDR-MV1 headphones with 24Ω impedance, I originally tried the normal mode and it was fine but it got loud too soon and I wanted more granular control, so I changed to the high sensitivity mode and now even at that I don't have to crank up the volume even to half, it is loud enough before that, and I don't know if its placebo effect or what, but I think it is a bit more clear with less overwhelming bass, while not sounding thin at all, compared to its normal mode, of course that's just subjective test and not measured.
Now this is a big deal for me because my iD24 had too much output impedance (22Ω?) which I felt it affected my headphone's sound, now I can listen to music from Mac, turntable and other devices with my headphones and get the best sound out of them.
I also have the HD 560S (120Ω) but have yet to test them with it.
The interesting part is it can have these settings separately for each headphone out, and also you can change the headphone outputs to become line outs, not my use case though.
3. ADAT input
I wish it directly accepted SPDIF too, but it is still better than nothing. I can connect my SPDIF devices to Audient iD24 and use its ADAT output to give them to SSL 12's ADAT input, also it can be used as an extra analog input source, maybe connecting my cassette tape deck too, so I'm glad this ADAT option is there, but it wouldn't hurt them to make SSL 12 SPDIF compatible, it seems they have done it for SSL 18.
4. 32-bit
I know the 32-bit claim is mostly marketing, and for 32-bit integer the difference isn't that dramatic and it still doesn't reach the limits of 24-bit in practice, but I read somewhere where they guessed SSL 12 is using a cheap old AKM Codec ADC/DAC chip which is 24-bit in ADC and 32-bit in DAC, but on Audio MIDI setup of macOS it shows as 32-bit on both:
So that rules it out? Or it may show as 32-bit still then?
5. No sleep/delay/pops
Something that scared me of the new DACs intended for home use is their practice of using some kind of power save/sleep, so after inactivity for a while if you play something you either get delayed start of the sound or sometimes a pop sound too, I got it with my Fiio KA17 and heard some other devices do it too. I have heard there is some driver option on Windows to disable that feature on some DACs, but no such setting exists on Mac, so I'm glad SSL 12 doesn't do it, at least not encountered it yet.
But please beware that SSL12 can make a loud sound in cases of firmware update/restart of the device, so be careful.
Thankfully SSL12 has an on/off button too so you can prevent it most of the times I guess.
6. USB Bus-powered
It just uses the USB port for power (USB 3.0 900mA for power, 2.0 compatible for audio) which I know people hate for low headphone output power, but for my headphones it is more than enough and I love not having to plug another device to my power outlet.
A Question:
If you have been patient and read all this, I have a question too:
I have my CD rips, Spotify Lossless and iTunes purchased music at 44.1 kHz, so I have set the output to it for bit-perfect playback.
But doesn't it negatively impact my line-in input performance for Turntable and other sources?
Any sample rate suggestion for my use case?
Feel free to ask me try stuff with it if you are curious.
And if you want measurements, please tell me what exactly to do in REW or other Mac compatible software and I will try my best.
1. Line-in Inputs:
- Normal
- High Sensitivity
- High Impedance
- Line Out
3. ADAT input
4. 32-bit
6. USB Bus-powered
A Question:
