I am a purchasing equipment to make DIY Headphone Cables for a HD800s, and it would be great if the community could check the soldering materials & equipment I plan to purchase. I read through these posts on the forum:
https://www.audiosciencereview.com/forum/index.php?threads/flux.12645/
https://www.audiosciencereview.com/forum/index.php?threads/rca-soldering-on-a-pcb.9577/
Please note this is my first DIY headphone cable, and I have zero soldering experience. I probably will do the work on top of my granite kitchen island.
Soldering Station: Hakko FX-888D ($105)
It is about double the price of more budget options, but from what I have read it is highly recommended. I like its modular design, and seems like this would be the first and last hobby-grade soldering iron I would need to purchase.
Solder Wire
I'm not in love with the thought of purchasing lead-based solder, but my research says lead-free is more difficult to work with (especially for beginners) because of a higher melting temp, and a longer dwell time. I am aware that the EU banned the use of lead in electronics in 2006, but metal lead is very inert so as long as I practice good hygiene, I think I'll be OK.
I plan to use 63/37 solder since it is eutectic and more beginner-friendly according to this guy (https://neurochrome.com/pages/choosing-solder). With that out of the way, let's look at some price points and options for 63/37 on Amazon:
RadioShack 1.5 oz 1.27mm 63/37 - $4.67/oz
MAIYUM 100g 0.6mm 63/37 - $2.81/oz
Kester Rosin Core 1lb, 0.5mm 63/37 - $2.31/oz
J&F Rosin Core 100g, 0.5mm 63/37 - $1.98/oz
Kester Activated Rosin, No Clean, 1 lb, 0.78mm 63/37 - $1.66/oz
Kester 1 lb, 0.78mm 63/37 - $1.63/oz
Kester 1 lb, 0.5mm 63/37 - $1.62/oz
This is where I get confused - what diameter wire should I use? Seems like the smaller the better for this application. Should I use "Activated" and "No Clean" solder? I'm leaning towards the MAIYUM because I doubt that I will ever need more than 100g of wire & it is recommended for electronics, but I could be convinced otherwise.
The silver doped solder seems like audiofool bs (http://www.circuitnet.com/experts/86531.html )
Helping Hands
The cheap ones <$15 all have mixed reviews. The ones between $30-$40 seem like overkill. Can someone recommend one? Is an attached magnifying lens useful?
I like this one because it has adjustable clamps, magnifying lens, and LED lights for about $20: Carson Helping Hands
If the magnifying lens is unnecessary, these seem like a good option for $30: QuadHands Mini Helping Hands
Soldering Fundamentals:
What is the best soldering 101 resource I should read?
Thanks in advance.
Solder Wire
Helping Hands
Thanks in advance.
