Keith_W
Can you suggest (link to?) low cost examples of such units for use per stereo pair? Low cost as in family meal out territory
@dualazmak can talk to you about how his VU Meters work. I'm sure he would be delighted to do so.
So, for calibrating gain to ensure no clipping, for speaker protection with e.g. drunk teens using the system for parties
Is there a line level device to perform this function after the pre-amp?
Or do you need to measure something at speaker outputs?
Am I called, because of my DIY-built 12-VU-Meter Array? If so...,@dualazmak can talk to you about how his VU Meters work. I'm sure he would be delighted to do so.
I do have one I will be testing, picked up an Alesis 3632 cheap on eBay but againdo you mean a limiter?
The blinky lights are nice but I already have a pair non-accurate ones for that purpose.
I was hoping for reco's on a simple OTS cheap & cheerful gadget for occasional calibration purposes.
or a link to a HowTo just use say REW or an SPL meter for that purpose?
The tachometer in a car isn't a true analogue to the clipping indicator in an amplifier. The point is that the available power isn't sufficient. When an engine reaches its maximum RPM, it doesn't mean the power is insufficient, but rather that the driver was too incompetent to shift into the next gear.Yes. Seems to me to be the "emperors new clothes" of the hifi world.
I get that it's probably overkill for lifestyle things like Sonos etc, but for proper hifi gear, seems like a no-brainer to me.
Hate to use the dreaded car analogy, but it's kinda like a performance car without a tachometer.
Very odd.
That's exactly the point: the tachometer only tells the driver the engine speed; the rev limiter is there for protection.Sure, but I guess the analogy with the tachometer is that they are also there to prevent damage to the engine/speakers.
And personally I would rather have some indication that the potential for damage is happening. Better than nothing surely.
Thanks for the explanation. Does this mean that it should be impossible for me to damage a pair of Tannoy V12s using a Topping Mini 300? The Tannoys have a sensitivity of 97db, and made for 400W Programme, 800W Peak.That's exactly the point: the tachometer only tells the driver the engine speed; the rev limiter is there for protection.
But as I said, it's about power.
Most amplifiers don't clip anymore; instead, their output power is limited, especially Class D amplifiers.
An amplifier could only protect the speaker by overloading it if the maximum power output were limited.
Most users don't even understand what clipping is.
These days, speakers (drivers) are damaged by three basic processes:
- Excessive DC voltage at the amplifier output, which can affect all drivers. This is usually due to a lack of protection or a poorly designed protection circuit.
- Excessive power for the speaker, which in most cases affects the woofer first, both electrically and mechanically, but can also affect the tweeter, depending on its maximum power handling and crossover network. Midrange drivers are very rarely affected.
- Clipping usually affects the tweeters first, as the flattening of the sine waves results in excessive power being delivered to the voice coil.
In the last 15-20 years, I've rarely heard or read about damage caused by clipping, and damage from DC only really occurs when the amplifier is defective.
Most damage is caused by excessive overloading. This is easily recognizable by mechanical damage to the cone or voice coil, or by broken voice coil wires, even in tweeters. Of course, the voice coils can also burn out.
These days, we have many unsuspecting and inexperienced users who don't even know when or that they are excessively overloading their bookshelf speakers.
I've experienced this myself many times, and the mechanical failures of woofers, for example, KEF speakers, demonstrate this impressively.
Especially when used without subwoofers in AV systems, when watching movies, or in 2.1 systems without a sufficient high-pass filter, such speakers are often damaged by overload.
A built-in subsonic filter, ideally with an adjustable frequency to adapt it to the speakers, e.g. 20-50 Hz with a high slope, would be many times more useful, as it would protect the speaker and also delay clipping considerably.
Not hard to do. AD/DA DSP between preamp and amplifier.
One of the simplest things one can do is to monitor the differential voltage on the (explicit or implicit) operational amplifier that most power amps resemble, or in more general terms, monitor the error signal. When it starts to sky-rocket, the amp cannot regulate the output anymore for whatever reason and the feedback loop opens.A genuine clipping indicator can only function correctly if the incoming waveform is compared and analyzed against the outgoing waveform.
This would then be independent of impedance and frequency ranges.
OK, but my scenario is electronics that are capable of physically damaging my speakers long before clipping occurs at any stage in the chain.REW+SPL meter does not measure clipping
I've read from credible sources, in order to get "max safe" SPL from my OG LS50s, the HPF / low end crossover to midbass couplers, should be 170Hz or higher.A built-in subsonic filter, ideally with an adjustable frequency to adapt it to the speakers, e.g. 20-50 Hz with a high slope, would be many times more useful, as it would protect the speaker and also delay clipping considerably.
Unfortunately after contracting Covid several times I no longer have much sense of taste/smellAs for human monitoring of speaker overload, the nose is a good sensor too, at least for ported speakers. When the port winds start to smell, it's time to turn the volume down ;-)
It would not be wise to ask or answer such a broad question. Find an amp you're interested in and do the research and find out if the particular model you are looking at has the sort of protection circuit(s) you desire.Can someone confirm that modern Class D chip amps should have inbuilt protection that prevents clipping?
If so, this is quite great news and quite a game changer for me.
Thanks in advance.
Limiting isn't necessarily better than clipping. As you turn-up the volume the peaks are limited (or clipped) but the overall average power still goes-up and it's the short-term average which overheats voice coils.So my request is for a HowTo make the judgment call as to what SPL point to limit input, whichever device I use to do so. Just a link would be fine, and from any member...
Amir's measurements don't show that. The distortion usually makes a big-jump upwards. You push the amp beyond its limits and it clips. Some amps tend to "soft clip" which is similar to limiting. Tube amps tend to soft-clip.Can someone confirm that modern Class D chip amps should have inbuilt protection that prevents clipping?
