Not hard to do. AD/DA DSP between preamp and amplifier.
Can you suggest (link to?) low cost examples of such units for use per stereo pair? Low cost as in family meal out territory
Maybe not just for this function, would be a good spot to do "per-speaker as anechoic as possible" compensation EQ
and maybe bandpassing enclosures, rather than spending more on 4-channel crossovers?
I am using a mix of one-driver "active system" boxen vs passive multi-way speaker enclosures with internal crossovers
> Then you set up the gain structure so it can't exceed the amps input rating for full gain.
For speaker protection, assuming the amp even at clean levels below clipping has capacity to blow out drivers, would the lower setpoint required need to be set just by listening for distortion, then backing off say 3dB?
> Or you don't worry about the gain structure use soft clip limiter.
Does that work like signal compression? My understanding is this approach is not as good from a SQ POV for high SPL listening?
I got a Alesis 3632 cheap on eBay to try for peak limiting, but not sure how well that will work, might affect SQ?
keyword Modularised audio DSP
