Obviously we know of the advantages of a waveguide - improves dispersion matching between tweeter and woofer, increases sensitivity around the crossover, and so on - but what disadvantages do they have other than somewhat more complex engineering?
In that sense, as in many others, they stand out.I'm sure both Genelec and Neumann have enough knowledge on hand to design waveguides despite being relatively small firms.
I don't think there is anything like a waveguide optimizer available that will suggest the correct shape for a specific build and specific response. It's still trial and error, with more error unless you have the resources of a large firm. Or enough formal physics in you to solve the underlying wave equation.
Correct. Neumann calls its waveguide Mathematical Modeled Dispersion Waveguide (MMD™). It's their trademark.I know of knowledgeable DIY people defining cost functions in the waveguide simulation software and iterating them in an external optimisation toolbox like from Matlab, so I am quite positive the procedure can at least be partially automatised.
The following is just my opinion.
A waveguide presents opportunities to screw up. The throat is an especially critical region, as is the mouth. If there is only a limited amount of space in which to fit the waveguide (which is always the case!), then a tradeoff has to be made between how far down the waveguide is effective AND having a large enough round-over to minimize mouth reflections.
If a small diameter midwoofer is used, and if pattern-matching in the crossover region is a goal, the resulting crossover frequency may be so high that you still get a lot of off-axis midrange energy on the midwoofer's side of the crossover point, resulting in a spectral imbalance between direct and reflected sound despite the pattern control of the waveguide over its region. Dutch & Dutch gets around this by using cardioid loading for their 8" midwoofer. I think Amphion does the same for their three-way models.
Regarding higher order modes, or reflections within the horn, my understanding is that they are present in all horns. Earl Geddes was the fully appreciate their implications, and to use a geometry optimized to minimize their generation, namely the Oblate Spheroid. So while the term comes up in discussions of waveguides, this is actually an area where good waveguides are better than most horns. (Waveguides are a subset of horns, so all waveguides are horns, but not all horns are waveguides, by Earl Geddes' usage of the term.)
I have used waveguides or waveguide-style horns in all of my home audio loudspeaker designs for the past fifteen years. I have measured most off-the-shelf waveguides or waveguide-style horns. Just like virtually everything in audio, they are not all created equal. And there are always jugglings of tradeoffs involved. Imo the advantages are generally worth pursuing, and the tradeoffs are fewer and/or easier to juggle in a large speaker versus a small one.
I also had problems with... the much larger wave guide (or maybe it's a non-wave guide horn?) on the Geddes Abbey.
Gedlee Abbey had a waveguide. Difference from Summa was just diameter. Earl didn't make anything less than a waveguide for Gedlee speakers.
@Dennis Murphy How did you narrow it down to waveguide problem in that pioneer speaker ? For that to be possible, you'd have to use the exact same tweeter, just without a waveguide. Is the original Pioneer tweeter equipped with ferrofluid and what is the replacement tweeter you've found to sound better than stock ?
