As to using other than sub pre-outs for the subs (why you would need the regular channel pre-outs for such is beyond me) just use the designated sub pre-outs. I generally only have to use the input level adjust for low input level sources like a turntable (but that's just to help the volume control be more equal over various sources, won't provide "extra" output).
Thanks a lot Peng! Yes the Yamaha has only xlr inputs. I bought two xlr connectors and wired them to to a rca.There was totally no sound coming out from the Yamaha.Btw,the yamaha was bought second hand could be faulty.I've since returned the yamaha to the seller.
Abt using the Denon's internal amplifiers,are you referring to the Assignable channels? Someone told me I could use the unused Assignable chanels to power passive subwoofers. Is that true?
Also,I found that the 4308 has input level controls that can be be set higher than the default 0 db. Is it ok to increase these input level controls? B'cos I normally stream music from you tube and sometimes the sound seem quite soft.The denon's volume has to be ard -10db in order to get good sound output.
Much appreciate your help with these issues.
