Justdafactsmaam
- Joined
- Nov 13, 2023
- Messages
- 1,282
- Likes
- 1,003
That’s a tautological argument that ignores the fact that crosstalk is crosstalk regardless of where it happens in the audio chain. There is no such thing as “natural crosstalk” you are misapplying an adjective to make a semantic argument. Crosstalk is crosstalk. It’s objective and measurable. And it’s effect on the sound doesn’t depend on arbitrary labels of natural or unnaturalIt's an obvious fault in the component chain if the channels leak into each other already in the electrical domain, opposite to the natural crosstalk that occurs in the acoustic domain, where both ears should hear the sound of both channels similarly as the ears would hear a real sound 30 degrees in front of them.
You just made that up to suit your argumentA sound that is not canceled out in the opposite ear.
No, it isn't. Even if the recording is mixed to a separate left and a right channel, and the playback consists of one left loudspeaker and one right loudspeaker, it doesn't mean that the sound of those two channels is exclusively meant to be heard just in the left or the right ear.
How do you know what is “meant?” That is an assumption.
For a stereo recording to sound natural, we must be able to hear everything in the mix with both our ears in the same way as we would hear the sounds live.
That is just patently wrong. If we are talking about *recordings* sounding natural you are dead in the water with any studio multi track recording. We are then limited to minimalist recordings of acoustic performances. And make no mistake about it. Crosstalk cancelation will give you objectively more accurate and more natural imaging, sound staging and and ambient hall retrieval by an order of magnitude.
YesAsk yourself this: If a real sound object was positioned 30 degrees to the left in front of you, wouldn't you hear that sound with both your ears and be able to know exactly from what direction that sound was coming?
That’s not what crosstalk cancelation does. You are conflating actual live sound that eminates from individual sources with stereo play back of a recording of such objects. THERE IS NO CROSSTALK TO CANCEL in real life. If you record an object at a 30 degree angle the recording picks up the spatial cues and encoded them discreetly in 2 channels. If the playback adds crosstalk it is corrupting those spatial cues.And take that experiment further, do you think you would be better able to pinpoint that sound position more accurately if you blocked your right ear with your finger?
This is a bizarre experiment which assumes there is a universal desire to locate images on the speakers.In the example below you have the left channel only of a Norah Jones song.
https://www.dropbox.com/scl/fi/m12w...-sec.wav?rlkey=8ncp6ex7ah2fmhwbx7dllchnm&dl=0
1. When you listen to this track you will hear that the sound is coming from the exact position of the left loudspeaker, that is of course expected because that IS the exact position of the sound, and that's the correct direction this sound IS coming from.
2. Try now to keep your head looking straight forward between your speakers and now block your right ear with your finger. By doing that you will most likely notice that the sound seems to be coming from a position outside the left speaker, but do you find this to be more correct than when you heard the recording with both your ears? No, you shouldn't think that because you fully well know that is not a more accurate way of hearing it. But still, that's exactly your argument when you say that the sound would be more accurate if you use crosstalk cancellation.
There is no crosstalk to cancel in a normal 2-channel audio production either
Actually there is but you are conflating recording with playback.
You keep on making this same semantic argument by misapplying the word naturally., that is if you like to hear the mix naturally in a similar way as our hearing normally works in real life. It's of course perfectly okay if you may subjectively prefer the recordings with crosstalk cancellation, but please don't say it's a more accurate way of hearing things.
And I will keep saying it’s more accurate because it is more accurate and that accuracy is easily demonstrated. I’m not going to back down on facts because they don’t fit your narrative
You are simply in incorrectYes, yes, and yes. But crosstalk cancellation will not solve those problems, and unfortunately, it introduces new problems.
