yeyeyey.ipa
- Joined
- Apr 4, 2024
- Messages
- 20
- Likes
- 63
Hello everyone, my first review post here. Hope you'll like it.
This is detailed measurements of Snowsky Retro Nano bluetooth reciever that can also work as a USB DAC. It was sent to me by one of my friends.
It costs about $60 US dollars.
The battery is replaceable, which is awesome since this device is intended to use as a portable Bluetooth DAC+HP amp. It has a 450 mAh battery in a 10440 form-factor included. It is not as popular as others, but still, you can find it.
Measurement setup:
FiiO provides us with these specs:
Let's begin with measurements!
This is Frequency response with no load applied at 96 kHz sample rate.
Nothing interesting here to comment, it is flat in audible range.
This is 1 kHz FFT @ 0 dBFS output using unbalanced jack. Since this device is limited to 16 bit, I've added 16 bit dither in generator. So, we are limited here to 16 bit in terms of noise.
The device has two gain stages. At high gain, max output is 2 Vrms @ 0 dBFS, and at low gain is 1 Vrms @ 0 dBFS.
Dynamic range is limited to 16 bit and is measured at 97.2 dB. I am sure that if there would be an option to use 32 bit output on USB, the result will be much better.
Multitone performance is good. We have about 18.3 bits of distortion free range.
This device has no choice for output filter. However, I don't see any issues with its work.
J-test shows scary distortion. My guess that it won't be audible and won't cause problems in most cases, but it's up to you to decide. I noticed that this is not unique issue to Retro Nano, Hiby W3 II also have it. I've found this article where jitter measurements of Hiby W3 II can be found. Clearly there is something to improve.
In terms of power, I measured 110 mW at high gain, and 31 mW at low gain using 32 ohm load. I only measured unbalanced output because I don't have a suitable 4.4mm - 2.5 mm adapter.
Edit:
Output impedance is measured at ~0.1 ohm. Nice!
At 300 ohm load, we have 13 mW at high gain, and 3.4 mW at low gain.
I also measured this device at 10.4 ohms load. We have 62 mW at high gain, and 2.1 mW at low gain.
Edit: I forgot to add a THD+N vs frequency measurement. Here it is.
"Cirrus hump" measurements.
@jkim noticed that devices based on CS431xx could have a "hump" visible at multitone measurements. I strongly recommend checking his post about it. So, let's test it.
FiiO added a DRE toggle in one of the recent firmware, so I checked the difference between DRE turned on and off.
In TDFD Bass vs level measurements, turning DRE off clearly shows improvement. Since this device is limited to 16 bits of range, I'm showing IMD vs level and not TD+N vs level.
In Multitone vs level measurements, it shows different distortion pattern than other CS431xx based devices. Still, DRE adds a lot of distortion.
PEQ test
I've added some filters in REW EQ section and generated a response from these filters. This became a reference.
Then I measured a frequency response with these filters uploaded to device.
And there is a mismatch! I am not sure why this is the case; hope you'll tell me.
Conclusion
I like this device a lot, it has lots of features for a small price. Performance is not the best, but decent overall. With 10 band PEQ (unfortunately not per channel) and Bluetooth capabilities I think there is little or no alternatives to it.
I hope you liked this review, and I wish you best day!
Measurement setup:
- E1DA Cosmos ADCiso Grade B set to MONO mode;
- a TrueRMS DMM;
- E1DA Cosmos Scaler used as a buffer to increase ADC input impedance;
- E1DA Cosmos Load Board.
Edit:
PEQ test
Conclusion
