snake oil or science? new from Furtech...
MDAguy
San Francisco Bay Area
Makes no sense to me and they never really say what it does except "makes sound and video better" with references to fancy processes and "static" and "dampening" which make no sense when talking about mains AC. I would say snake oil is a safe assumption.
Man those guys are smart. Any kind of plug it in and forget it kind of device with no immediately obvious effect is an easy sell. They are hopping on the bandwagon that includes PS Audio, Shunyata and High Fidelity Cables. And probably others.
Sounds like an MOV to me so if costing more than $1.75, snake oil.
Now, I do fully recommend a "whole house surge suppressor" installed on the main panel. Not that it will make any difference in your sound system, but it will protect things plugged in to some extent. I have had electronics blown by proximity lightening strikes.
I am not at all against a DC blocker on the power strip feeding your system. Again, real science, real problems, real solution.
If some magic lines filter improves your stereo, then you have some POS equipment with a poorly designed power supply. Don't blame the mains or look for a magic fix. Buy/build a decent piece of equipment! I also suggest an MOV as part of your power supply design.
All you have to do is read the description in the link, to know that it is some kind of nonsense.
Once again, if any of these power line products did what they claim, the would be so busy selling them in the scientific, instrumentation and medical fields that they wouldn't have time to think about hi-fi.
In the absence of any further evidence, I use the Precautionary Principle such that Furutech=Snake Oil until proven otherwise.
S
PS. Ditto for any other cable or audio accessory company.
I've measured a few AC noise filters which do reduce crud far out of the audio band, but does it really matter? Usually not.
Probably a film capacitor in a box.
