Not really - there's snakeoil for every price-point on this thread.Hey, this is supposed to be high-end snake oil, not chiptune!
But assembly language is definitely easier to write and compile if your power cables are specially designed to eliminate non maskable interrupts and invalid op codes.Hey, this is supposed to be high-end snake oil, not chiptune!
FYI: In english it is called Assembly (language).
Assembler might be the cobble together the commands “assembled together”?
I see.I wasn’t trying to nit pick.
NMIs can be darned useful.But assembly language is definitely easier to write and compile if your power cables are specially designed to eliminate non maskable interrupts and invalid op codes.
I mean, isn’t that obvious?
Did older consoles have a toroidal transformer, given that this is a topic of interest to audiophiles...?But assembly language is definitely easier to write and compile if your power cables are specially designed to eliminate non maskable interrupts and invalid op codes.
Don't be crazy! - we did however have to place our RS232 cables on raised plastic bridges in order to ensure the bits used for treble got to the device when testing.Did older consoles have a toroidal transformer, given that this is a topic of interest to audiophiles...?
Yup. I always keep some with me… IIRC Andrew Braybook used some in his games… Audiophile NMIs sound better, but cost more cpu cycles!NMIs can be darned useful.
12 Apostles's? [sic?]"apostrophe's"
That's this oneIsn't the pope a Cathodic?
A response is valuable if you have investigated it yourself. A prejudice adds nothing. These are not expensive manufacturers with marketing stories but enthusiasts who, among other things, Have investigated themselves. Costs are about 35 dollars.Maybe you are seeing something that I am not, but those eye pattern results tell the story…they are all clean enough that there would be no bit errors were introduced in any of those tests. That means the file would be the same regardless of whether the cores were installed on the ethernet cable or not. Also if there were bit errors, they would sound like a click or a pop if they are heard at all. There can be no improvement in sound (other than the absence of clicks/pops) as that would require co-ordinated changes to the file…something an ethernet cable, with or without ferrite cores, cannot do.
Are you sure it's prejudice and not technically informed opinion? If it's the latter, the prejudice lies elsewhere.A response is valuable if you have investigated it yourself. A prejudice adds nothing. These are not expensive manufacturers with marketing stories but enthusiasts who, among other things, Have investigated themselves. Costs are about 35 dollars.
Problem is I have investigated. I am familiar with eye diagrams, I am familiar with ethernet, I am familiar with very large ethernet installations, I have designed very large ethernet networks and I have supported very large ethernet networks. Never have I recommended ferrite cores as a fix to a problem, particularly when the eye diagrams show there is no layer 1 problem. That type of reasoning would have landed me in very hot water not only with my former* customers but with my former* employer.A response is valuable if you have investigated it yourself. A prejudice adds nothing. These are not expensive manufacturers with marketing stories but enthusiasts who, among other things, Have investigated themselves. Costs are about 35 dollars.
