To laugh or cry... maybe both.
Ideon Absolute Stream meta edition is $24,000 and its optional add-on, the Ideon Alpha Wave LAN Optimizer is $6900
For your $24k you get an off the shelf motherboard, some fancy power supplies and a Linux OS. And of course the power supplies provide enough capacity to drive an amp cause big numbers are impressive to the gullible even though the power draw of a MB, SSD drive and some USB ports is tiny.
What is "cheap" (and comical) is rather then hardwire the Ethernet and USB ports at the chassis end, they use standard cabling with plugs. So that's one extra join/junction (which might be prone to vibrations) but I am sure whomever buys this will use $$$$ external USB and Ethernet cables potentially not knowning that within the chassis the cabling is of a "lessor" quality.
You would think, for the money, they would be using something more "high end" for the internal wiring.
And while maybe not important, why house the SSD drive directly under the USB/ethernet cables... surely you would, for the money, isolate the SSD drive away from other components. And indeed isolate the power supplies with internal walls... to at least give an impression of having given some thought to the internal placement of parts for your $24k.
Anyways, the review highlights all the usual stuff about why you need to spend $24k on a box with one ethernet port, five usb ports, a standard mother board, an SSD drive and a Linux OS (and I am sure a whole host of FOSS [as in free] software joining it all together). For example, its easy to create a computer that works as a Roon server or endpoint as Roon provide the sofware needed for free.
Peter
