Yes I totally understand the use with speakers, it's self explanatory.If you turn your head in relation to your speakers, something happens.
They translate that to headphones so that the headphones sound like speakers.
Which may or may not be of value to you, the lizzener.
As for jogging... They could have an initial reference direction, which would be good till you turned a corner. Maybe a reference reset would be useful. Maybe strange running laps.
But the headphone application is confused , it makes no sense to me. No speakers , no tv just headphones but you need a tracker??? And it works if you record the output from the device and play it back on your iPod when on the tube train??
Bizarre totally bizarre. You head won't be moving on the tube train like it will at home?? It's confused.
I am sure you don't need tracking with just a pair of headphones.
You want to be in the sweet spot at home with your speakers right? So you want the out put of the speakers to change in time as your head moves.. This makes total sense , I knew about this system years ago but it was very expensive.
So if you use headphones you have negated the problem of your head moving and taking you outside the ideal performance window in relation to a speaker set up.. where is it advantageous to then implement the failing of a speaker set up.. The headphones are on your head, static.
It makes no sense, you head movement won't be a repeatable event so how on earth if it works as amir says can you then record the out put and still maintain effect when on a tube train or at a bus stop.. Your head won't be moving as it did in the original event.
Weird.. Very weird indeed.
