archerious
- Joined
- Aug 10, 2020
- Messages
- 255
- Likes
- 148
Does this still have smsl DPLL?
I am pretty sure I saw reference to it in the menu.Does this still have smsl DPLL?
Sure. Just start a conversation with me.....I'm considering buying a Wadax Reference server ($90,000) and Wadax Reference DAC ($190,000) combo (CA$, breathe) but would like to see how they measure ; could you, please?
If it weren't for the chrome ring on the volume knob, I'd want this component to replace my Adcom preamp.
Thank you! The confirmation that it has quick volume ramping means I can use it as a Pre, and that makes it a buy for me.Got mine delivered yesterday.
I choose this one because : I don't care about MQA - wanted a firmware that could be updated.
Displays don't show 99 anymore, "time off" or "no display" options are included in DIMMER menu.
Remote control look the same, less confusing buttons. Remote +/- won't work if fixed output is on.
Volume Up and Down from remote is quick, tried but I don't use it as I've got a balanced preamp.
They add customs filters to play with.
I feel really happy with this very nice DAC !
Question, do you mean that the “99” is not shown because you can turn OFF the screen? Or is it that when you set it to fixed output it will show a different thing instead of volume level?Displays don't show 99 anymore, "time off" or "no display" options are included in DIMMER menu.
Yes, there is a new DIMMER option in the menu. It lets you choose "screen auto time off" from 5s to 60s.Question, do you mean that the “99” is not shown because you can turn OFF the screen? Or is it that when you set it to fixed output it will show a different thing instead of volume level?
You use the scroll wheel to change inputs.Did they remove the button to switch between bluetooth and Usb or optical input?
There's a button to switch from BT/TosLink/SPDIF/USB on the new remote control.Did they remove the button to switch between bluetooth and Usb or optical input?
Wouldn't be even nicer if we can have access to the real schematics ...Would anyone be willing to open an SU-9n and take some pictures? It would be interesting to compare with SU-9: https://www.audiosciencereview.com/...s/smsl-su-9-balanced-dac-review.16150/page-23
This was a popular belief 40 years ago among audiophiles and even then scientists knew it was completely untrue. That alone destroys this guy's credibility, in my opinion. Even in a normal listening environment, most people can hear distortion that is half that or less. I believe that in an ideal situation, the threshold is below 0.0002%, but I'm not positive about that number, and it would never apply outside a lab environment.You can’t hear THD or noise under 1%.
Try this THD test. I used headphones for the test.This was a popular belief 40 years ago among audiophiles and even then scientists knew it was completely untrue. That alone destroys this guy's credibility, in my opinion. Even in a normal listening environment, most people can hear distortion that is half that or less. I believe that in an ideal situation, the threshold is below 0.0002%, but I'm not positive about that number, and it would never apply outside a lab environment.
Now, I also have had doubts about the value of this DAC, so I'm not disputing that fact. I just would not base my buying decision on misinformation.
Thanks for sharing that link. That is a very useful test, as long as people use it only to determine the absolute highest the level can be before they hear it. I've tried that one before, as it is really convenient. I'm not sure if it is due to the compression on the video, tinitus, my poor current system combined with the fact that "a quiet listening environment in Phnom Penh" is pretty much an oxymoron, or simply the way the test is designed (an ABX test between an "undistorted" signal and one with varying levels of distortion would be much more accurate, but also take a lot longer, more tedious, and probably get a lot fewer Likes), but my results are all over the place ON THE SAME SEGMENT. The best I can personally say after 20-30 tries over a few different days and doing my best to randomize my starting points so that I did not simply start subconsciously tracking the time, is that I THINK I can hear a difference starting at 0.2%-0.3% on all three tests. But at the other extreme, there were times when I didn't hear it until 2%. There was even one where it got to 6%, but I disregarded that as the AC compressor 2 meters away kicked on right as I started listening.)Try this THD test. I used headphones for the test.
Also take into consideration that the SINAD score is just a measurement at one frequency at one output level--and in some components the equipment has been specifically designed to maximize the performance on this specific measurement over providing better results overall--AKA, gaming the system. So just because a DAC has a SINAD of 120db at 1KHz at 2 or 4 volts does not mean it will be anywhere near that high at at all frequencies and all output levels--in fact, you can be pretty much guaranteed that it will not. It is just one of many useful measurements.From the comments:
"well, the measurements are utterly meaningless. They have literally no effect to the listening experience. That’s all Topping and SMSL seem to be doing these days—releasing a product every month with slightly lower THD or marginally higher dynamic range. You can’t hear THD or noise under 1%. And you cannot listen to music above 90db for long without damaging your hearing. So, what difference does it make when these products measure well? It’s such a shame ASR refuses to put its measurements into context."
Hi ABSNimes,Got mine delivered yesterday.
