manuallyDoes this Dac has auto turn on/off function? Or we have to turn it off manually everytime we dont use it?
Hello to all,Hello.Show a photo of the display with the updated firmware number.Many people are interested!
I got this one...@SHENZHENAUDIO What would be the display's showing on the latest firmware update? Thanks.
No 2020 on my Versions menu. Is this the one updated Firmware?
Hello to all!Hello to all,
Trying to figure this out before returning to Amazon.
I noticed this...
Every Version Screen I seen have the Year 2020 on it, mine does not!
Here is my Version Screen.
I believe this can serve as a difference between old and new Firmware.
I received this from Amazon, no side serial sticker, no DAC# Serial, long serial at bottom, and no 2020 in Version screen.
Serial# 3460010300196.
Can anyone with the new Firmware confirm their Version screen to see if this is the one for the updated Firmware?
Thanks to all!
Ryctor_
Hello there!Also meant to add .. on the theme of measurements.. the RMA allows you to reduce the ESS correction taking the distortion back to 0.1 % and guess what .. I would part with a crate of beer for anyone who can hear the difference in a blind test!
Did run it for a week .. hoping every new session would be better.. but that never happened . Maybe I had a duff one (but that points to poor manufacture) but I did listen to just left and right .. both expressed similar traits .. not flat to my ears.Hello there!
I am new here as well.
Really appreciate all who contribute to this very special place.
I came from the Studio. Worked in the MI for the Recording Studio Scene for over a decade now.
Was able to place together Demos for Top Producers and Studio Recording Facilities (Criteria, Studio Center, Circle House) on the top AD/DA Brands, on site, for them to select their favorite, completely subjective. The gear stayed sometimes for a week, so they could compare and choose.
Brands like Burl, Benchmark, Avid, Apogee and Dangerous Music, Weiss, Crane Song.
In every case, the DA of each unit needed to be turned on and passing audio for a good two days,
for the Electronics to settle and the buzz and shrillness, that I found naturally present in any out of box brand new DA that I have tried (same for mic Preamps. SS or Tube).
No difference with the SU-9. I played well known recordings in HI-Res, and the shrillness and fuzz,
almost make me feel that this was a pro-sumer device. Monitors Neumann KH120
I let it run for a week, and came back. I was wrong.
Thin? (Again, subjective, with respect...) Not here...
The thickness of the bass and the textures in the low mid and mids, make this device perfect for mixing.
Compared with Crane Song Avocet, Heritage RAM2000, Dangerous Source, the detail, resolution and layers are very defined and help to position instruments in the stereo field very easily. Instruments pop out from the black background, like if someone is whispering in your ear sometimes. Nothing trying to make the audio prettier, just honest, thick, layered sound.
OTOH, one of the most used DA for Monitoring, mixing and Mastering, Dangerous, sounded a bit augmented in the mids, perfect for mixing, however, I found the SU-9 more honest to the track.
A great representation of the space where the tracks were recorded. Reminds me Apogee Symphony DA. The measurements say the same, but I tend to use my ears, you cannot mix what you cannot hear.I do not hear numbers.
I wonder what your thoughts would be if you kept the SU-9 and let it go through some audio so everything settles.
And, with respect to all please, do not start the burn in is brain getting used to, I did not listened for a week, and electronics, including caps, transformers, tubes and opamps do sound different (not better) after the initial 48 hours of playback.
Not saying that you would not have still preferred the RME, but I have had some RME (ADI-2 FS Pro) conversion here as well, and the SU-9 wins.
Go figure, I found the ADI-2 thin, with great detail, but nothing to do with the impact and textured thickness of the bass and mid bass on the SU-9. Mids is where the MIx is. (Pop, Folk, some EDM, Rock and Fusion). All subjective, I know, but...
Blind tested, volume matched to .01 db. wife switching the RAM2000. SU-9 wins.
Also preferred SMSL SP200 headphone amp, compared to Apogee, RME ADI-2 and Heritage RAM2000 diamond buffered headphone amps.
If I needed PEQ ( I dont, plenty of plugins and an Elysia XFiter on the Master Bus), or DSP, a nice display, etc, the ADI-2 wins. But the SU-9 is still here.
Horses for Courses, just leveling the field a bit.
Happy listening to all.
R_
Hello there!
I remember thinking that the SU-9 was Dark! And also thought it was not flat.Did run it for a week .. hoping every new session would be better.. but that never happened . Maybe I had a duff one (but that points to poor manufacture) but I did listen to just left and right .. both expressed similar traits .. not flat to my ears.
People say that the RME is neutral .. if that means the bass extension is evident and is really tight .. the mids are equisit and both male and female vocals forward of speaker plane and super crystalline highs with nothing fatiguing then yes I agree.
The su-9 was not that beast on the system .. I do hope others are finding it so as I also had aspirations towards.
All I would say is if you get the chance to try or compare the RME ... Do so (if course I think my ears are correct!).
One other thing I noticed on the su-9 is I could detect treble roll off on the slower filters (not enough to solve the problem though) but I have tested recently as having no hearing above 12khz.. does not seem to fit the published graphs?
Also, I just noticed, Do you preferred the AD18 to the SU-9? How is that possible?I remember thinking that the SU-9 was Dark! And also thought it was not flat.
Same with the RNHP. Measures Ruler Flat, and jet you hear a warm sound, like the Sennheiser Veil, on one of the most used Studio Headphones.
Its Presentation, I noticed things on the SU-9 that I had never heard before on any DAC. The information has always been there, SU-9 showed it to me.
Is your room treated?
Low end can cancel itself with standing waves in a room.
I just cannot conceive the sound from the SU-9 as thin. Mostly vs RME conversion, which have been described many times as thin, analytical, boring. I find it dry and fatiguing. I think you like the display too much... LOL! Did you did a blind test?
Again, completely subjective, as both measure superb, and are ruler flat in the FR.
Horses for Courses.
R_
Some things I mentioned that may be slipping through the net.Also, I just noticed, Do you preferred the AD18 to the SU-9? How is that possible?
AD18 better DAC, SU-9 thin? RME extended bass? I will advise you check your room...
Happy listening!
