Windows 8.1 is old and my understanding may be wrong, but when connected using DXIO Pro3z as USB/spdif converter, it is output by Window's standard USB driver. The installed SMSL USB driver will not be used.Hello !
I have a problem when using my SMSL SU-9 with USB connect
I will try to relate what is going wrong
I use SMSL as an USB dac connected to my computer, Samsung running Windows 8.1 x32 updated.
The computer reads Flac files from usb external hard-disk
The computer runs Jriver 26
This is a basic system, I use to play for many years, and before to try SMSL USB interface, I was running DXIO Pro3z as USB/spdif converter to Twisted Pear ESS9018 Dac
I had to download drivers (5.00) from SMSL website, and install on my computer
When USB Input is selected on SMSL, I can see the driver is reaching the USB input, some comments and parms : 44.1khz 32 bits, buffer size 512 default selection
When I try to play music, Jriver locks during 30-40 seconds before beginning to play, as if there was a contention between driver and device.
Usually , with USB Spdif interface , when music is starting, in a previous config a brief "buffering " appears on Jriver top screen , may be 1/4 second
With SMSL usb connected, the message "Buffering " is present during the lock, 30-40 seconds , then disappears and music plays
Does anyone have experienced with this kind of problem ?
Thanks for any help
You haven't said anything about the output settings for Jriver 26, but I think you need to specify the SMSL USB driver for the output and make sure the related settings are set correctly.
The buffering time can be such a long time operation depending on the setting of Jriver 26.I think you have probably chosen full buffering.
