SMSL SU-8 Version 2 Balanced DAC
Oukkidoukki
When they arrive just plug in decent headphones if you have some and listen to some good recording songs, please. I know measurements are important. However, how great a unit sounds vital "at least" for me. Thanks.
I don't have high end headphones.....I have dt 770, akg k702, senheiser hd-25 and o2 headamp....let's see.....or should I say hear
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
No multimeter but audio decibel meter....I try to match with that.......my friend will change the xlr cables between the dacs then i guess which is which.......i dont have switching box nor wanna use one in fear of fucking up the signal path.........btw. when I said old rme adi 2....its not from last year.....its from 2004....first adi they made..
Then switch, and have him listen. Should be interesting.
klimal
Check the voltage dip-switch is correct for your country.
Change power cord and try again
Oukkidoukki
I sent it to some Kelly already....it was contact email in SMSL site.....she answered and told to contact schenzen audio. So I did. Waiting for the answer....
BDWoody
Chief Cat Herder
Moderator
Ookeeyyy then...........so su 8 came but it doesn’t power up.......any help?
Bummer man...I hope you get it sorted out.
Always disappointing when stuff doesn't work. I'm sure you will be taken care of, but...still...
Oukkidoukki
Yeah, thanks man.........Let’s see.........after waiting 18 days you feel quite empty to start sending it back somewhere :)
Oukkidoukki
Oukkidoukki
Yeah, there is somekind of fuse....pic is from the net....can't open because of the warranty...
