Hello. First it is unlock, then it jumps to "no signal" then when I connect the USB cable to the computer the display shows 44.1 but no sound because the computer does not detect the SU-8. I tried to reinstall the drivers, changed the USB ports, changed the computer and still no sound. When it is connected to the USB longer, the message UNLOCK appears. You cannot see the SU-8 in the XMOS program or anywhere else. The other digital sockets are working properly. I uninstalled all devices from USB ports. I reinstalled XMOS. Now computer displays "USB device not recognized"?Does it show 'unlock' or '44.1'? I don't think it's both at the same time. If it shows the sample rate, that's normal behavior, if it stays on 'unlock' forever, that's bad news
Have you tried also?:
- Re-installing the driver
- If you disconnect the USB only from the computer and keep it on the DAC, does still says 'unlock' or 'no signal'?
- Try feeding the DAC with all digital inputs, then switch between them and see what happens when you get to USB
- On your Windows sound settings, do you have the SU-8 selected as the default playbak device?
