Gradius
All I can say is my E30 died in less than 6 months of use.What’s the best DAC SMSL SU-6 or Topping E30? Thanks
It should works. The problem is the driver from smartphone.Has anyone tried connecting their smartphone with an usb-c output into the usb-c input of their SU-6? Can you connect it that way and play music from your smartphone instead of connecting it with bluetooth.
It should but I could never get it to work and so I had to pay $28 to send it back to Shenzhen audio in China to get it fixed.Has anyone tried connecting their smartphone with an usb-c output into the usb-c input of their SU-6? Can you connect it that way and play music from your smartphone instead of connecting it with bluetooth.
We'll see. I tried multiple cables and multiple phones. I even bought an Oculus-approved cable to make certain that I was using a cable that was made for data transfer...Acerun, I think you wasted $28. I doubt if the problem is with the SU-6. You phone must be able to route the audio to the usb jack also the cable you use must have the capability to pass data. Some cables are charge only. Good luck.
The unit has a remote control that includes volume control.Hi guys! I recently bought a SMSL SU-6 to use as a preamp along with the Rotel RB-1080 power. I intend to use practically 99% bluetooth to listen to music, my question is if it will work the way I expect, being able to control the volume through the remote control? Thanks for the help direct from Brazil!
Yes, it is that nowhere did I find anything saying that it could be used as a preamp like several other SMLS or Topping DACs connected directly to the amplifier.The unit has a remote control that includes volume control.
The unit has RCA outs that you can connect to an amplifier or to powered speakers. Bluetooth signal in and then out through RCAs. LDAC sounds great on the SU-6.Yes, it is that nowhere did I find anything saying that it could be used as a preamp like several other SMLS or Topping DACs connected directly to the amplifier.
Haven't tried with a transport, although I could make the set up if nobody answers. What I can say is that with the TV toslink output there are zero problems.Hello. Has anyone tried connecting CD transport via SPDIF to SMSL SU-6? Does it have dropouts (CD/DVD players jitter problems) like Topping E30? Thnx.
I've used the Topping E30 for about a year and now the SMSL SU-6 with a Onkyo DX-C390 CD changer without any issues so farHello. Has anyone tried connecting CD transport via SPDIF to SMSL SU-6? Does it have dropouts (CD/DVD players jitter problems) like Topping E30? Thnx.
Good call; It's the SMSL DO100.What you you think, a few more months and this comes out in a balanced version at $199?
wow. Will need to experiment with that... In about 6 months when Shenzhen audio returns my unit...A USB-C to USB-C data cable also does not work for me. But I found something interesting: @Acerun @Masterbrewer @Gradius
It is not an issue with the DAC as such but with the cable/smartphone... Using a Samsung USB-A to USB-C adapter connected to the smartphone (Samsung S10) and using a "standard USB-A to USB-C" cable is working like a charm. All audio is routed through the DAC to my audio system.
But it only works if the adapter is connected to the smartphone. If you connect the adapter to the DAC and connect the cable the other way round does not work.
I am not an expert in cables but I would like to understand the differences!
