SMSL SU-2 DAC Review (NTTY)
Rate this DAC
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 1 1.1%
  • Good (***)
    Votes: 21 23.9%
  • Excellent (****)
    Votes: 66 75.0%
When you refer to the player only, the pre-emphasis flag is part of the toslink datastream. But the Dac has to be capable to de-emphasize, analogically using a low pass filter oder digitally
so, as I assume, the SU2 is not capable to do so.
Not a big deal I hope, I believe I may not have many CDs that have pre-emphasis, although I do have a lot of CDs that date '80s, but to my understanding many pre-emphasis CDs were special Japanese prints.
Not at all... The CD where I realized missing De-Emphasis was an European release. But it is really like selling a car with three wheels,, as the SU-2 is meant for CD-Playback the first place. And the ES9038Q2M is still active and provides De-Emphasis,, SMSL could have taken this DAC. Sent mine back today after a long hassle with the seller, who tried to deflect the fault to my hardware and later tried to reject the fault by remarking that the de-emphasis capability had never actually been advertised. But it never needed to be advertised, since it had always been part of Digital Audio standard. I would stronly advise amir and NTTY to check for emphasis in future reviews. Here is a list:
I agree this CAN be grounds to get a refund, for those that care.
If that feature is indeed required to meet some important standard (which?) then ES9039Q2M should be avoided by the relevant manufacturers, and consumers.
When RIPPING a CD the FLAC file should be created with that feature enabled, right? Then no worries in future decades...
If you want to waste your free time ripping CDs. I’ve only ripped my absolute favorite CDs so I can listen to them on the go—about 150 GB. At home, I use my CD player and sometimes a backup of the rips, which are organized into folders, without all that overcomplicated junk like iTunes. I use Vox.
Here are even more CDs, I count 660.
And there are a few real classics in there that I also have in my collection.
And if you want music on a physical medium that doesn't crackle or hiss, you buy used CDs
We all must abide by the consequences of our choice, or choose to make different ones.
Personally this DAC is such good value, if I cared about a CD featuring De-Emphasis, that would be top priority for ripping.
But then I often compromise in my life choices, call me Mr Workaround.
I am not in any way denigrating those who are more willing to Stand Up for Principles
I have enough dacs, that can actually do emphasis - if someone helped me with this one, I had my perfect one:
Well, I originally bought the SU-2 to know that top notch specs are beyond what i hear. Could have the same specs with this 16-Year old Dac, as 4 Channels run in parallel for each stereo channel. Opamps are still top notch.
Best Bang for the Bug ;)
I bought 8 of them for my 7.2 Surround CamillaDSP aktive Project connected to an RME HDSPe AES Card to get 16 analogue Channels for less then 900€ at all ;)
And there i don't need all that fancy stuff (USB, Blutooth, I2S on HDMI and so on...) only AES in and XLR Out!
Nice Review :)
I can't wait to hear/read about your project! Any shared content so far?
Curious - what kind? I almost went into CNC - milling with a Datron Neo...
DATRON NEO ...how much it cost 100000$ new???
My was a lot cheeper if you don't count the Time i needed to build it all up LOOOOOOL
SOROTEC Compactline 0605 with an Jianken ATC 1,5kW Spindel and EdingCNC 720 Controler.
Bare Metal Set ;) X 600mm Y 500mm Z 190mm:
https://www.sorotec.de/shop/Portalfr-smaschine-CL-Line-10866.html
Here my last job i did with it:
IMG_20260917_174855_7.jpg Fahradstern fräsen.jpg IMG_20260917_205156_7.jpg IMG_20260917_205203_0.jpg
Is for an Bycikle off my Brother in Law. Did it on an Suckingtable or how ever you name it ;)
The Hole in the Midle is exactly 40.00 in X and Y measured with an Mitotoyo digital Vernier caliper, the Tabel i measured like on the First Picture, has an tolerance off 0.004mm on an Rectangle off 200x300mm for now but want to made the CNC a bit stifer on Y Gantry than i will plane the Table again. After moving into my new Place.
Watercooling and Housing also the Electrical Stuff i made by my self.
CAD Design:
Not the best Picture but cannt find a better one for now:
IMG_20260525_164243_2.jpg IMG_20260512_181711_8.jpg IMG_20260504_163231_8.jpg IMG_20260424_165340_5.jpg
Watercooler with an Radiator:
Reached 40°C in Stator after one Hour of cutting while envirement Air was at 24°C and Water @ 26.6°C on Radiator in 24.3°C @ Radiator Out.
Was my first Test with it on this Job some Days ago.
Wow! In 2016, I contemplated to start a High-End Audio business and joined with someone who built prototypes and already had a Neo. He could have built his own CNC but already had customers, so buying a used Neo was better. Our Deal was to work as a lathe operator for him and to mill my own prototypes for free. But we needed a bigger CNC machine for my plans. While waiting for funding decisions, I finished my first full length documentary film which became a moderate success. So it is now filmmaking…
I start to build the CNC 2018 and still not finished but i used it already for my Projects ;) and like always this CNC Project was escalating a lot since then .....
The cheepest thing was the SOTOTEC mechanical Part Set LOL
Thanks for a fantastic review @NTTY
This is very close to the device I need : SPDIF and optical inputs, no USB at all, and XLR outs.
This will make my search for a good preamp easier, as I can factor the DAC out of the preamp, and just focus on the best measuring fully analogue preamp I can find with a great volume pot and XLR ins, and perhaps a phono stage and tone controls.
Now my crucial question is: does this SU2 detect which digital input is currently in use? Does it automatically switch to the active one?
My sources are a SMSL PL200 which would go in via optical, and a Raspberry Pi4 + Allo HAT going in via SPDIF.
I wouldn't want to have to use a) the button on the SU2 DAC to switch between the two digital inputs above, and b) the interface on the downstream preamp to switch between SU2 input and other analogue outs.
Reactions: pma
My sources are a SMLS P200 which would go in via optical, and a Raspberry Pi4 + Allo HAT going in via SPDIF.
I've just found the manual https://download.shenzhenaudio.com/download/6969a3380a7f3.pdf
Page 9 states
I'm hopeful that the bit below:
automatically detect the input when starting and automatically find the input with signal
means what I hope it means - but can any actual users of the device confirm?
I tested it, SU-2 was on AES and i have connected Source to SPDIF IN, after aktivating Signal into SU-2 it has not automaticaly switched to SPDIFF, i need to do it manually!
But if it switched off with aktivated AES last Time, it's detects the right Input and switch to SPDIF after Power On but not if it was On the whole time!!!
Only detects the Input while switching it On.
Here some Importand Info to know!!!
SU-2 was not able to handle 1ns Jitter on Input (AES or SPDIFF)
MOTU UL mk5 did it easely on SPDIF IN!!!
Here my Measurings:
https://www.diyaudio.com/community/...ound-digital-aktive-setup.440807/post-8413719
SO keep that in mind!!!
The so caled ck-03 Clock Module (Jitter eleminator circuit) does nothing on that DAC, i woul d say ;)
For me an MUTEC MC-4 did the Job and cleaned all up infront off SU-2, reaching -122dB THD+N again.
While Using HDMI to AES / SPDIF Extractor with 950ps Jitter!
MOTU did it on his own there!
That means for me: you can't gett all the fancy stuff for Cheep, there is an reason why something is Cheep ;)
There isn't any fanzy PLL Reclocking Stuff going on SU-2 that could Fix Jitter.
On the other Hand would all DAC'S be able to be Synced without Phaseshif between different DAC's if an Recklocking Module on each DAC would do his Job indepandend ???
I am not an Developer so no clou here ;)
I sent mine back, after a long and ridiculous exchange of emails with the seller hifi-cat, where they tried every ridiculous explanation to prevent payment of the shipping costs and not charging a restocking fee. Up to the point that they stated they would unpack every device and test it before shipment. Later they demanded I should ship the SU-2 to a buyer in my country on their behalf in case they found one. Reason for shipping back was the lack of de-emphasis and of course they did not know what De-Emphasis is. I had to open a case via Paypal and it took many phone calls to get the shipping fees back from Paypal. Normally they do not do this, also even when the item is defective.
