What I do NOT do anymore, is let the connection type have much influence over my device choices, unless it literally makes no difference to the value proposition which for me prioritizes CS Quality & Reliable Longevity, top of the list.
If I'm not mistaken, your "rant" and my "diatribe" are in full agreement. Essentially:
- Balanced vs. Unbalanced (SE) is only about eliminating noise (CMRR) introduced into the interconnect cable.
- There are some cases in a home setting that will audibly benefit from a balanced receiver device. For example: long run interconnects to active speakers (non-issue for speaker wire to passive speakers); situations where you cannot avoid running interconnects and power cables in close parallel proximity; living in a high RF environment that introduces audible noise, etc.
- For the remaining (and vast majority of) home hi-fi situations, there is no noise-related audible reason to prefer one connection type over another.
On the other hand, sometimes the equipment we want to purchase — based on features, reliability, aesthetics — has balanced audio ports. And so we buy it, not because we needed the balanced noise rejection (CMRR); but rather because it was the best device based on our selection criteria. And that, in turn, can affect future purchase choices... not because we needed CMRR noise reduction on the interconnects, but rather because of compatibility with that equipment we had already purchased.
In my case, I have several components that support balanced connections because they were the right functionality for what I needed: Ashly LX-308B analog stereo mixer, RME ADI-2 Pro interface, KH 120A speakers. I can easily connect all of them using unbalanced (SE) cables and will still have absolutely no audible noise! But I use balanced XLR/TRS cables because it is already supported anyway... and it feels cool.
Which brings me to my purchase of the SMSL SU-2 DAC (S/PDIF => Balanced) instead of just using my TOPPING E30 (RCA) to connect digital devices to my Ashly LX-308B mixer.
My decision for the SU-2 has absolutely nothing to do with noise reduction or some "purity of balanced audio" since there is no issue with audible noise in my environment. Rather, it is for consistency — the high voltage output from the SMSL SU-2 DAC (vs. a typical unbalanced DAC) will be easier for gain-level matching against the other devices already connected the stereo mixer (i.e., TOPPING D10Bs) that also have higher voltage.
So even though the higher output gain of the SU-2 (4.7V) vs. D10B (4.2V) will not be identical, it is a heck of a lot closer and much easier to gain-level match than the wider difference of the E30 (2.0V) vs. D10B (4.2V).
And 100% also true: any unbalanced DAC with a ~4V voltage output would work just as well as the SU-2... the issue for me has nothing to do with balanced vs. unbalanced; but rather keeping consistency with what has become common for "balanced audio" voltage vs. the standard output voltage on consumer devices.
/end diatribe
