SMSL SU-2 DAC Review (NTTY)
Rate this DAC
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 1 1.1%
  • Good (***)
    Votes: 21 23.9%
  • Excellent (****)
    Votes: 66 75.0%
I sent mine back, after a long and ridiculous exchange of emails with the seller hifi-cat, where they tried every ridiculous explanation to prevent payment of the shipping costs and not charging a restocking fee. Up to the point that they stated they would unpack every device and test it before shipment. Later they demanded I should ship the SU-2 to a buyer in my country on their behalf in case they found one. Reason for shipping back was the lack of de-emphasis and of course they did not know what De-Emphasis is. I had to open a case via Paypal and it took many phone calls to get the shipping fees back from Paypal. Normally they do not do this, also even when the item is defective.
Ok, Deemphasis is nothing i bother about and i know that SU-2 dont has it, also no MQA, before i bought the SU-2.
Also i tested 3 of them on first Stereo aktiv Setup and it worked well, but i had not made any Measurment at this Day, the COSMOS Stuff i bough last week for measurments or so ;)
Here some Importand Info to know!!!
SU-2 was not able to handle 1ns Jitter on Input (AES or SPDIFF)
MOTU UL mk5 did it easely on SPDIF IN!!!
Here my Measurings:
https://www.diyaudio.com/community/...ound-digital-aktive-setup.440807/post-8413719
SO keep that in mind!!!
The so caled ck-03 Clock Module (Jitter eleminator circuit) does nothing on that DAC, i woul d say ;)
For me an MUTEC MC-4 did the Job and cleaned all up infront off SU-2, reaching -122dB THD+N again.
While Using HDMI to AES / SPDIF Extractor with 950ps Jitter!
MOTU did it on his own there!
That means for me: you can't gett all the fancy stuff for Cheep, there is an reason why something is Cheep ;)
There isn't any fanzy PLL Reclocking Stuff going on SU-2 that could Fix Jitter.
On the other Hand would all DAC'S be able to be Synced without Phaseshif between different DAC's if an Recklocking Module on each DAC would do his Job indepandend ???
I am not an Developer so no clou here ;)
Apologies, I am not able to follow your point. Maybe try feeding a summary of your observations written in your native language to Gemini or equivalent and then repost here?
Having quickly googled the MUTEC C4, it seems it's a 1000 euro device so I don't see how the comparison is relevant?
On the actual device, if I understand correctly you've identified a source of jitter on the SPDIF in? This would be disappointing
@NTTY did you observe this in your measurements?
HDMI has always more Jitter than an SPDIF connection, that is well known, not the best digital connection because of the integrated Video sync Stuff.
My Bluerayplayer has around 250ps Jitter on SPDIFF Out at the same Time my HDMI to AES / SPDIF Extractor shows around 950ps Jitter on SPDIF Out while feeded from same Bluerayplayer but HDMI Out instead of SPDIF.
My Scope can't meassure Jitter directly but you could see the difference with your eyes, Clock Phase is changing more on the right Picture!
left SPDIF OUT Player, right SPDIF OUT Extractor while connected to HDMI Out from Player:
And my Measurings show that MOTU ul mk5 and Musicfidality V90DAC is not afected on its analogue Out, while connected to the Extractor SPDIF Out, but the SU-2 shows artifacts on THD+N measurings, also reduce his THD+N Value around 9dB -112,7 instead -122 on an clean SPDIF.
Red MOTU on Extractor, blue V90-DAC on Extractor, orange SU-2 on Extractor:
HDMI to MOTU SPDIF diecrly Mains Out.jpg V90-DAC on Extractor SPDIF.jpg Extractor to SU-2.jpg
If i connect the MUTEC in between, Extractor (AES) to Mutec (AES) to SU-2 (AES) it is clean like Motu and V90 DAC on its own, without needing MUTEC at all to clean digital Signal after Extractor!
Yellow MUTEC between Extractor and SU-2, Blue SU-2 directy on an clean SPDIF Out from MOTU Interface (No HDMI involved)!:
Jitter < 1ns is not realy much but not Perfect in High End thinkink.
I hope now you understand.
Why the SU-2 can't handle it by its own??? It has an Jitter eliminating Circuid implemented, SMSL says but it seems that 950ps already to much for it???
I payed 720€ for Mutec MC-4 (B-Ware, normal price was 869€ on Thomann and now it wen't up to 998€, WOW) but not to clean Jiter but for SRC Usecase, i need to up or downsample all incomming Samplerate's to an fixed 96kHz Samplerate for CamillaDSP on RME HDSPe AES Card!
Here it cost stil 869€:
https://www.da-x.de/de/mutec-mc-4.h...7K2v7Ljmkun1iVNvZdaEEbmRTWvtS7RhoC7lMQAvD_BwE
And i like the Fact that it is capabel to clean Jitter as well for my usecase after Extractor ;)
You could also use an VanityPRO Extractor (1600€) that removes Jitter already while extracting HDMI 7.1 Signals
https://www.stereophile.com/content/audiopraise-vanitypro-hdmi-audio-extractor
But it is / was not aviable for longer Time! And i wan't to buy an ATMOS Capabel Processor with AES Out in the Future ;)
SO this way i still could use my MC-4 on the Processor, if i like, and throw only 300 to 400 € for the DYI Parts away if i can't use them for an other Project ;)
If i have done something wrong please made youre Statement, where this Artifacts on SU-2 coms from, if not from Jitter.
I can reproduce it again and again.
The AES/SPDIF inputs of the SU-2 will sync to the incoming signal, as intended. The internal Clock of the SU-2 is more than precise enough for what it has to do, as my J-Test has shown on all inputs. If the source suffers jitter, some of it will transition to the SU-2. The SU-2 has a PLL to synchronize with the input signal. A PLL can't completely ignore the source clock, and so if the incoming clock slowly drift, the PLL must eventually follow it, otherwise would lose lock.
So, I don't understand why blaming the SU-2 for jitter coming from the source. There's no re-sync/re-clocking in the SU-2 but a standard synchronization (PLL) to align its internal clock to the one of the incoming signal.
Of course an ASRC can do a better job at filtering low frequency Jitter, it's the interest, but it's not what the SU-2 offers, as most of the DACs.
To be honest, your posts here and there on diyAudio require unreasonable efforts to understand what you're trying to achieve and your associated concerns, because only so few parameters of your tests are shared at once.
Again, why an old cheep V90-DAC can handel the incomming signal and SU-2 not? We don't have extreme Jitter from Source >1 ns???
Easey Question?
Also SU-2 says it has an Jitter eliminator circuit but it seems not to work with my <1ns Jittery Source.
So i ask why ?
What means then "Jiter Elinminator" on the Paper, nothing???
And i wan't only to show that this could happen!
For my Settup it works fine with MUTEC and RME Card in Front of that DAC and reaches his promised THD+N Values!!!
I have 8 SU-2 in use !
I am not here to Blame anyone,
i wan't to share my expireiences with my Build and that there could be Problems with Jittery Sources on that DAC,
other DAC would not have that same Problem !! If it is build right! Like i showed!
Truth hurts always, i know ;)
Now i am the Bad Guy LOOOL
Seriously?
If you want to make fun of people and companies, so be it. But I would recommend you read what I took time to write above and before.
Your V90 is performing re-clocking and upsampling on all inputs, reason why you don’t get the same results.
The SU-2 does not have that re-clocking feature, and does not need it.
Last reply from me to you as I don’t appreciate this type of interaction.
"If you want to make fun of people and companies, so be it."
I have never done it!
But my First Language is German so may be i am not able to get the right Temper for my Word'S. don't know.
"The SU-2 does not have that re-clocking feature, and does not need it."
What means than "Jittereliminator circuit" ?
I am not an Developer and so i don't know what or how they reach it!
Means it only for smal portion of Jitter like 100ps ? or up to 500ps i can't know it, right?
If this Device don't do reclocking how they reach Jitterelimination at all then?
Sorry that i am only an Hobbyist and don't know the Math / Technical aspeckt behind.
But ok let's stop it, for me it works like it should on my Chain and reached the -122dB SINAD like promised.
I think there's an underlying issue here that many of the jitter tests by Amir, NTTY and others are performed using good quality digital audio sources.
These will show whether or not the DAC is adding it's own jitter. In the case of the SU-2, it is not.
What these tests don't show is how DACs perform with poor quality sources. In other words, how much do they reduce the jitter on the incoming digital audio.
I've been trying hard to understand what Frunse is doing. It's not easy, but it's been worthwhile (I have also recommended before that he uses a translator).
He is trying to get top-tier stereo system performance from an immersive multi-channel system, based on sources with HDMI outputs.
To the best of my knowledge, he is the first person ever to do this and demonstrate it with high quality measurements (using E1DA DM ADC, APU & Scaler).
He runs Camilla on a PC to perform the DSP functions. The AES/EBU input/output is handled with an RME HDSPe AES PCIe card, before feeding 8 stereo DACs.
He managed to get very good measurements using a MUTEC SRC to reduce the inevitable jitter from the HDMI audio extractor.
The MUTEC reduced jitter when driving the SU-2 directly.
The MUTEC reduced jitter when driving any DAC directly.
The MUTEC reduced jitter when driving the RME which then drove the SU-2.
The MUTEC reduced jitter when driving the SU-2 directly, but with the RME in between the HDMI extractor and the MUTEC.
Without the MUTEC, the jitter went straight through the SU-2 DAC.
Without the MUTEC, the jitter went straight through the RME.
Without the MUTEC, the jitter was reduced when using both the MOTU and Musical Fidelity DACs.
What this shows is that both the RME and the SU-2 don't add any significant jitter, but neither do they reduce it, which is a surprise.
It also shows that the MOTU and the Musical Fidelity are both effective at reducing jitter, as you might expect from good, modern DACs.
The behaviour of the SU-2 surprises me because SMSL claim it has a CK-03 clock module to eliminate jitter, plus it uses the ESS ES 3039Q2M DAC chip. That's a high-end stereo DAC, which unlike lesser models, has an SRC in the digital signal path in between the digital filters and the modulators. Usually indicates good jitter performance.
The RME HDSPe AES also surprises me because RME state it has SteadyClock FS, which is an EXTREMELY effective jitter reduction tool. If RME says one of it's products is good at something, I trust what they're saying more than pretty much any other audio company.
Something doesn't add up, and I'm not sure what it is. It might just be a matter of configuration or settings.
Yes my understanding is it comes from Jitter, but RME Mastermind says, it could be something different
You mocked Matthias Carstens from RME.
It's quite obvious he's a very good guy, and deserves respect.
He reads both DIY Audio and ASR.
He's someone that you want on your side
Thank You for understanding me! welwynnick
May be i am an old Bastard, but i only do question if something is suspition and i can't get why.
And even i don't neet to do this question because it works fine for me, don't need to bother about.
May be other's need to know this, if they wan't to do something simelar but withou willing to buy an MUTEC MC-4, thats 1000€ range now!
For them may be other DAC's are an better option.
On the other Hand may be exact this reason is why the SU-2 works how it works, keeping 8 independent SU-2 DAC'S from Phasedrift between them while geting his clock from AES RME Card. May be Dacs with own Recklocking will drift because they Reclock it to his own internal Oszilator (guessing, not knowing it)
I am not sure, i can only test what i have.
I will test it now with 3 v90-DAC's if they Drift or not but i need to make me XLR AES to RCA adapter for that test first.
And if someone was getting Harmed by my word's it was not knowingly! So sorry for them!
I have no Problem to accept that i did something wrong.
But Forum's are mad for discussion or not, may be i need to keep the German Side's then, but i can't reach much people like i use International Forum, right!
"He's someone that you want on your side" from
welwynnick​
Jocking!!! you mean the Dark Side, right, Luke ??? ;)
That was not my intention, i like RME as well, i wanted only to tell that it could be something different, not Jitter related and that this comes from Matthias! Not that he is wrong thinkink that way!
He is an professional i am not so i would beleeve him by sure! And for me Matthias is an Mastermind on RME ...no Jocking!
HDSPe Card has isolated In and Outs, so that makes me asking what else could it be..... \o/
The RME Card reduce the Level of Jitter / Artifacts to an Level in comperson but not that good Mutec did. That does not mean that Card done nothing! to stay clear ;)
Fantastic post, thank you for taking the time to writing this. Interesting discussion and would be curious to know what constitutes a bad source nowadays. People do build chain of tools of different vintages, after all.
May be not the right Thread for that Discussion thou, but SU-2 is involved and seems to be an unicorn without USB so .....
One of Frunse's notable achievements, which may deserve repeating, is that he made his own multi-channel HDMI digital audio extractor, integrating HDMI to I2S and I2S to AES converters. Not only does it work, but it works quite well. Respect to Frunse. Since it gets it's timing information from the HDMI, it's inevitable that there's quite a lot of jitter on the digital audio outputs.
There are precious few such devices.
Yulen AKA SoundProAudio make the HDMI to 5AES Black Box. I don't know much about this, but I expect this has quite a lot of jitter, too.
AudioPraise make one called the VanityPRO. It has very low output jitter, but is quite expensive. Amir measured around 10ps.
The alternatives like the Trinnov Altitude 32 and Storm ISP Evo are extremely expensive.
By contrast, using a PC for DSP duties allows the use of moderately priced hardware and software to perform any processing you could wish for -
  • Speaker Cross-Overs
  • Amplitude Equalisation
  • Phase Equalisation
  • Reconstruction Filter
  • Jitter Reduction
And do it better and more cheaply than any audio device. And use better DACs & preamps than any AV product. It's a fine ambition IMHO.
The language issue is very significant however.
I rarely bother putting in the time and effort to parse their lengthy posts to try to extract some meaning between all the LOOOLs and mispellings.
With free automated translation tools so readily available and easy to use
I REALLY hate the AI tsunami destroying our civilisation
but in this case I think just silly for Frunse not to use it
I need to say my first language was Russian, then we wen't to Germany when i was 4 Years old, they put me in german Scool when i got 6.
but anyway i learned now no LOOl's anymore and i am an silly old Bastard :)
I live like "Don't take yourself too seriously" and have fun.
I try to get better .....
The Problem on dyiaudio is after some minutes (30 or so) you can't correct the wrote Stuff or change or add something, so it is there for ever, even you wan't to change it or remove.
Yes, the SPDIF interface of the ESS chip uses an ASRC, but that does not mean SMSL went for it. I had a look at the inside of the SU2 and there's a QFP IC around the center-left, close to the clock/oscillator area and digital input circuitry, but I can't read its marking, so I'm not sure what it is/does but it could be the SPDIF interface feeding the ESS with I2S data stream instead of relying on the internal ASRC.
Frunse did not share a view of the standard jitter test of Julian Dunn, which would allow us to separate interface induced jitter from the internal one. But from what he shared, looking at the elevated noise floor and wider skirt of the fundamental, we could suspect 1) wideband jitter from the source, 2) poorer rejection of that type of jitter from the SU-2. That said, he should not be using the Cosmos APU for these measurements because that one generates a wider skirt due to the notch, probably hiding some of the "problem". Best would be therefore to run the standard J-Test without the Cosmos APU in the loop. But I won't be asking and won't be following up for the reasons I already mentioned.
When SMSL talks about the performance of their device in terms of Jitter rejection, they of course talk about internal jitter, and this is what Amir or I measure. We don't look at the interface's performance to reject induced jitter from an external source.
If we want a device to reject wide band / heavy jitter generated by the source, I think we talk a different type of device to address a different need. Of course there will be different implementations and engineering designs for a DAC, not to mention cost concerns. The more the features and capabilities and the higher the price, and/or the more compromises must be made.
I personally don't like SRC or even ASRC in the digital path, unless specific constrains and/or features the DAC designer wants to provide, high rejection of induced wideband jitter can be one, indeed. But an ASRC comes with some drawbacks, starting with resistance to intersample overs, or under/overflow of the buffer, delays, or other timing errors it might introduce and some could be considered against the purpose of the DAC (TBH most of which are properly handled in modern chips, and to be checked). But, yeah, to reduce wideband jitter from a source, an ASRC can be much more efficient than a PLL-based mechanism.
I remember years ago that Analog Devices was promoting their ASRC as Jitter-killer mechanisms. They were basically saying "Jitter is taking the good sample at the wrong time, or the wrong sample and the right time, it's the same problem". And so they were advertising hyper high multiplier of the sampling rate (like 1'000'000x), saying that if they could generate a pseudo-infinite number of samples, then any of them taken at the wrong or right time, would always be the "right" sample, and therefore Jitter was gone. Elegant on the paper, and working as intended, but coming with some constrains too.
To come back to the SU2. the below is a J-Test (16bits, from the optical out of a CD Player, the Teac VRDS 25x not to mention it), decoded respectively by the SMSL DO400 (orange) and the SU2 (Blue):
See the foot of the fundamental of the J-Test that is a little wider with the SU2. That could indicate a lesser resistance to wideband jitter, or some generated internally. I consider these too equally perfect.
Now, the below is the same test from the analog outputs of the Teac VRDS 25x (Green) and also from a SMSL R100 (Orange) that uses old DAC tech of the 90s:
Besides the more elevated noise floor, you can also see some side bands which are related to "sampling jitter".
At the end of the day, expecting the SU2 or any other DAC to reject wideband jitter from the source is not a feature of a DAC. Minimizing its own internal Jitter is. But if a DAC adds this feature and you need it, then that's cool, else it's just a waste of money and additional unnecessary processing.
Cheers
Are there cheap & cheerful DDC units that specialise in sample rate standardization? S/PDIF + AES/EBU out would be nice, USB input ideal
Are ASRC / SRC the same?
Edit: found Behringer Ultramatch Pro SRC2496
Dunno about its DA/AD aspects, but should be fine as DDC
Feed from miniDSP PocketADC, or Eitr 2 ?
Moved this Post to my Main Thread, don't need to be discussed here.
PHEW
The ES 9039Q2M does have an SRC, but I believe it's towards the back end rather than the front end, according to ESS Digital Signal Path:
However there are other DACs like the ES9017 that don't have SRC. The MiniDSP Tide16 uses the ES9017, and has conspicuously poorer jitter performance than it's recent, more expensive competitor, the Hyperion APR-16.
The rest of the post seems to focus on ASRC, and I share your reservations, but I think that's a distraction. What matters is whether or not a DDC or DAC is capable of minimising jitter, rather than how it does it. If a PLL is effective, then it's effective. If it takes more than one PLL stage, then so be it.
Hearing a system with properly controlled jitter for the first time about 20 years ago was a revelatory experience. It felt like I had never heard any of my CDs before, and it's been an obsession. Ever since then, I've been hearing people say that jitter is inaudible, or that it's a solved problem. I've remained very sceptical until recently, having seen Amir's DAC tests showing exceptionally clean jitter tests. The J-test in the first post of this thread is another. However, if that performance is only possible with an exceptionally clean source, then I want to know.
As an audio enthusiast, I want the information that will allow me to build a great system, rather than a collection of boxes that only perform well in isolation. Interfaces are often central to this. Most audio interfaces are well-defined and commonly agreed, but there are variations. If I have a power amplifier with low sensitivity, I know that I need a preamp with a high output level. If I have speakers with low impedance, I need a load tolerant power amp. Similarly, if I have a digital audio source with high jitter, I need a DDC or DAC that can effectively minimise that jitter. But I need that information.
One of the publications that I keep referring to is SoundStageNetwork. For the last few years they have been performing very comprehensive audio equipment measurements that include a lot of parameters that are not commonly tested, and I applaud them for that. One of those measurements is not just jitter with a clean input signal, but jitter with additional jitter added to the input. Some DACs can filter out that extra jitter, and some of them cannot.
It appears that the Musical Fidelity and MOTU DACs can filter out excess input jitter, and the SMSL SU-2 (surprisingly) cannot. And I think we need to know that.
