SMSL SU-2: a dumb, wasted opportunity
Well, it will be quite close to the price of Topping DX1 II which has a remote and a headphone amp so...
The SU-3 will likely be a simpler product than the DX1, but I'm willing to bet that it will also have way fewer bugs... o_O
Ok. Completely different price class than expected
Very affordable balanced dac, but SMSL strangely decided to not have usb input, by far the most popular input with tablets and pc.
But hey, it has AES that very few care. :facepalm:
And yes, the original SU-1 has usb.
I don't need that lousy USB—it's not even designed for audio transmission. AES, on the other hand, is exactly what I need!
Good news! You are on the right thread for a device that has AES input and does not have USB input.
For what it is worth: Since I do not need PEQ input, the SU-2 remains a sweet spot device for me.
According to Google, the answer to "is the SMSL SU-2 being discontinued?" is no.
But sadly, Google's answer to "is the TOPPING D10-B being discontinued?" — the SU-2's twin sibling for USB input — is yes.
Thanks. Had to google this Topping D10Bb and I don't see any twin-like resemblance with the Su2. It has a display, which I don't need, and has an USB input,which I don't need at all in my chain. My digital inputs are a CD player via optical and a Raspberry PI with an Allo Digione HAT via spdif.
This topping also costs more than the SMSL and I don't think I need to be paying for features I don't need.
Thanks. Had to google this Topping D10Bb and I don't see any twin-like resemblance with the Su2. It has a display, which I don't need, and has an USB input,which I don't need at all in my chain. My digital inputs are a CD player via optical and a Raspberry PI with an Allo Signature HAT via spdif.
I view them as fraternal twins based on what they have in common: no volume control, no PEQ, no remote control, etc. Just basic digital input to balanced XLR output. They are also about the only two DACs out there that fit that criteria.
And which of the two "fraternal twins" to choose is very specific:
  • If you need AES or S/PDIF input, then SU-2 is your choice
  • If you need USB input, then TOPPIN D10B is your choice (or was, unless you find used device)
I have both the SU-2 and the D10B because some of my devices are AES or S/PDIF and other devices are USB. You need SU-2 because your devices are S/PDIF (optical and/or coax) and not USB.
Is the SU2 being discontinued? I looked at the specs and it's EXACTLY what I've been looking for: no volume control, no display, no USB, and XLR out.
Why should the SU-2 be discontinued?
The SU-1 and SU-3 are not predecessors or successors, but rather different devices with a different focus.
