SMSL SU-1 Stereo DAC Review
Rate this DAC:
    Votes: 16 2.7%
    Votes: 15 2.6%
    Votes: 69 11.8%
    Votes: 487 83.0%
Here we go again :D
Yep, much more money to get = £189.
Sad really as I'd often imagined that the Xmos chip inside can do such EQ work... now I'm wondering if It's possible to MOD the SU-1 & it's Xmos chip to do such. But then the SMSL software would have to be hacked also to access whatever was needed to be added for the PEQ functionality.
Dunno what happened around the picture Bleib posted of the "New" SU-1... but it is actually an SU-3, similar to SU-1 it seems but with a 32 channel PEQ, & XLR outputs.
https://www.smsl-audio.com/portal/product/detail/id/960.html
Took a quick look to find lol wtf? lol
They appear to be two separate, new releases:
The SU-3 is taller to make room for XLR connectors on the rear, while the SU-1 DSP keeps the old shape but adds PEQ.
i assume you need some software to program the new su1-dsp and then it just hard codes it into nvram so it does the same curve all the time?
i mean there's no buttons on the thing
Programming is done in your browser via WebHID: https://www.dsptuner.com/connect
Yes, profiles are stored in hardware so you can disconnect the PC during use.
