Jimster480
A20D is like $200+.Unfortunately, the clicking noises were the problem with the SU-1. The noise on my headphones was so loud it was really unpleasant. It always depends on the components. But for me, it was only a €5 difference.
Are you using the three SU-1 for an active system via USB?
The Sabaj A20h is a HPA, but if you can get an older A20d (same chassis as the A20h) for that price, you should go for it. You won't find a symmetrical ES9038Pro for that price anywhere else.
I made a mistake on the A20h; it is indeed an HPA only. I was thinking it was similar to the M300 line from SMSL.
