radix
- Joined
- Aug 1, 2021
- Messages
- 1,456
- Likes
- 1,463
BTW while doing this mod I also want to put in additional 10uF electrolytic capacitors at the voltage rails of the lme49720 opamp the SU-1 uses.
This is recommended in the datasheet of Texas Instruments.
But I have no clue what DC-DC converter is being used by SMSL to provide the +/-12V the opamp needs from the 5V input.
Any ideas what IC is being used? I am asking this question because maybe putting in a higher capacitance at the opamp's supply
is ok with a dedicated dual supply but contraproductive with a DC-DC upconverter.
I think you are referring to this text?
11.1 Power Supply Decoupling Capacitors The LME49720 requires adequate power supply decoupling to ensure a low total harmonic distortion (THD). Place a low equivalent-series-resistance (ESR) ceramic capacitor, typically 0.1 µF, within 2 mm of the V+ and Vpins. This choice of capacitor and placement helps with higher frequency transients, spikes, or digital hash on the line. In addition to the 0.1 µF ceramic capacitor, it is recommended to place a 2.2 µF to 10 µF capacitor on the V+ and V- pins. This larger capacitor acts as a charge reservoir, providing energy faster than the board supply, thus helping to prevent any droop in the supply voltage.
I do not know what SMSL used, but maybe their engineers used what is needed for audio bandwidth signals based on the expected drive loads? Usually, it's OK to use larger PS caps (of the right voltage), but is it necessary? The board PS might be just fine for the use. Have you seen a problem with the output?
