i'm one of those that are perfectly satisfied with the gain settings. even with quiet classical recordings on my single ended dt880 600o HPs (5.3db gain), i'm pushing my ears at 75 high gain. keep in mind that unlike most amps, this amp is absolutely distortion free between 0 and 99 at any gain, so i have plenty of room to blow my ears out. for anything mixed a bit hotter, I have to lower to 50 or less. for my 300o, and 80o balanced HPs (11db), and 150o (5db) I'm between 20 and 35-40 high gain. I think I might have gotten to 50 with the hd600
I'm running my m400 balanced out at 80, so the input is slightly hot, but a number of people who were unsatisfied with loudness were also pairing with. m400s
re: whether it's worth the price. the sp400 has higher power and lower distortion at all gain levels than the sh-9 at a bit less than twice the price (with the preorder apos deal i got). however, it's debatable whether the difference is audible; the sh-9 is also excellent and as amir has said, both are "instrumentation grade". in fact, if you look at the pcbs of the two, it's obvious that they copy pasted the sh-9 time to make two sh-9s in parallel. if you are looking to maximize price to performance, get the sh-9. if you want a freakishly high power and low distortion fully balanced HP amp, then the sp400 is worth your time.
