could someone please explain what this menu setting exactly does? I don't get it from the english user manual... i could guess that it reduces the relay steps but maybe someone knows the exact purpose of this setting:
Agree. Will be great if manufacturers understand this.who wants a headphone-amp screen
The only reason for that device has been to match measurement criteria, it seems to me.Dang, that's a no-buy from me then. Having it remote controlled makes it especially good for a home-theater setup, but who wants a headphone-amp screen distracting them from a game or movie?
Just to offer that connector. But yeah it's a little bit misleading. They did the same on the SMSL SP200.So what is the purpose of the XLR Outputs if the circuit is not balanced other than misleading the buyer? Can't get it.
Upcoming Topping A30 Pro will also offer balanced out connector, but using (extremely powerful) single ended circuit. But the 4.4mm connector will have a dedicated ground return path so less noise and crosstalk. So in this case there's an actual benefit.
No, no. It won't somehow sound better when using balanced headphone cables. This is a good article:I have the SU-9 and the SH-9 connected via XLR cables. I'm using Emu Teak headphones. Would I benefit from using balanced cables on the Emu Teaks even though the output is single ended? Or should I just get a Topping A90 instead and run it all balanced?
Ok. Great article. Thanks for the info.No, no. It won't somehow sound better when using balanced headphone cables. This is a good article:
https://benchmarkmedia.com/blogs/application_notes/audio-myth-balanced-headphone-outputs-are-better
balanced can push out more volume, but I imagine that's hardly necessary for your Emus.
I plan to order Periapt cables for the Emu's. The article states that there's an advantage to using the XLR connection due to low contact resistance which eliminates distortion, unlike what I've read in previous posts stating that there's no difference. Do you think this would be noticeable in a five foot cable? I'd prefer using the 1/4 inch connection so I wouldn't have to swap cables going between the SMSL SH-9 and the Soundblaster G6 for my PS5. The Emu Teak 2.5mm connections are questionable.No, no. It won't somehow sound better when using balanced headphone cables. This is a good article:
Unless you can benefit from the extra balanced power output, there's no real probability of hearing a noticeable difference. You can try if you're curious enough, thoughI plan to order Periapt cables for the Emu's. The article states that there's an advantage to using the XLR connection due to low contact resistance which eliminates distortion, unlike what I've read in previous posts stating that there's no difference. Do you think this would be noticeable in a five foot cable? I'd prefer using the 1/4 inch connection so I wouldn't have to swap cables going between the SMSL SH-9 and the Soundblaster G6 for my PS5. The Emu Teak 2.5mm connections are questionable.
No, I don't have $70 worth of curiousness. Plus it's more convenient to skip the XLR. Thanks again.Unless you can benefit from the extra balanced power output, there's no real probability of hearing a noticeable difference. You can try if you're curious enough, though
It’s not balanced but it has XLR that’s kind of confusing. Why would they do that? Is the XLR just providing more power than the SE out? Are they just trying to confuse peopleThere is no balanced output either.
But yes, the price is good.
