As noted on Amir’s SA400 unit, the amplifier did emit a coil-whine like noise from within the unit which got louder as the volume was raised during the silence for testing, Amir says it would be likely not be noticeable with actual audio output through speakers (maybe the noise is still something to consider if intending to use the unit near-field).
I
do not think this is indication of poor reliability, but I am aware of many SMSL models which exhibit this behaviour.
I am not sure of the actual cause of the coil-whine, in my case I experience it occasionally with SU-8 V2 DAC and can reduce the noise level to near silence by setting screen brightness to minimum.
Recent models with larger screens seem to have a limited level of how dark they can get, so from some feedback I have read they were unable to reduce the noise level this way.
Another thing I noted is SA400 runs hot for a Class-D and has a fan built into the unit.
Apparently the
temperature at which the fan activates can be adjusted.
A similar model although more expensive is the new
SMSL VMV A2.
(I think internal amplification topology is very similar to SA400)
Other alternate models with less power are the SMSL VMV A1 (Class-A) and AO200 (which is apparently near identical internal topology to DA-9, but may or may not suffer from the same reported issues?).
