I bought SMSL DO300 and I think I became its beta tester.
- The device in the factory settings is +2dB by default,
- the default filter is fast linear, but more importantly, when the filters are turned off, the volume increases drastically and the sound becomes hoarse (Is there jitter mismatch? )
- The device does not have factory measurements,
- you can see and feel that someone was in a hurry to create this device,
- Device needs updating? I wonder when will the update be? I wonder if the update will solve all the problems, or maybe the device is poorly constructed?
A lot of questions and unknowns until the manufacturer measures it and even better if it was measured by Amir.
I know what I am writing about because I had DO200 mk2 before and I did not notice such problems there, but the device has been on the market longer and had the mk1 version.
Won't it be that the +2dB volume is set on the 5/2.5V outputs and the 0.0dB is set on the 4/2V outputs when we set it only in DAC mode, thus blocking the volume change?
If so, this is a very strange implementation.
