This is a review and detailed measurements of the SMSL RAW-MHA1 balanced stereo amplifier. It was sent to be by
Shenzhenaudio and costs US $199.99.
At first I was wondering why the display was not lighting up. But then saw the price and realized the volume control is analog, not rotary digital. Two nicely feeling mechanical switches complete the picture, giving a nice old school feel. You know, no menus, no pushing the knob to turn on the device, etc. Kind of refreshing. Even more refreshing was inclusion of power supply in the case which is a rarity:
As is full size XLR inputs. We even a bridging switch but no trigger or high pass for mains.
The heart of the unit is Infenion class D amplifier and not the common TI choice we see in this class. Let's see how it performs.
SMSL RAW-MHA1 Amplifier Measurements
As usual we start with our dashboard after setting the gain to nominal 25 dB, using the balanced XLR input:
This is respectable output, slightly beating our average for all amplifiers tested to date:
RCA input turns in similar response:
Neither has any mains contributions which is nice.
Noise performance is good for class:
Frequency response shows typical budget class D performance without the output filter being in the feedback loop:
As a result output impedance rises with frequency showing that peaking response.
Crosstalk shows resistive/constant bleeding between channels which I wish was not there:
Multitone test shows nice response where our hearing is most sensitive (2 to 5 kHz)
Again, as is typical, rising distortion at higher frequencies results in somewhat lackluster 19+20 kHz intermodulation results:
Company specs, along the lines of its competitors, is highly exaggerated. I could not approach them as I could not get the amp to clip in sweeps:
The amplifier would start to emit high frequency noise, causing the audio analyzer to stop gathering data. Might as well because that is the limit of clean power anyway. You can get a glance of what it can do during short bursts though in our peak power test:
The unpredictability didn't let me measure the max power. I did however, manage to capture 40 Hz power:
Not that you are going to use this amp to drive full range speakers but you do have good bit of power and more than what I could capture in the sweep at 67 watts/ch.
The Infenion IC amp shows more non-linearities than its competitor:
Noise is typical on power up and could be audible:
Finally, the amp was stable on power up:
There is a ton of competition in the "premium" stereo amplifier budget category. The RAW-MHA1 does not distinguish itself there from pure measurements point of view. But does score strongly in functionality as far as built-in power supply -- a nuances otherwise. And XLR balanced input. Performance is not bad, having scored above average compared to every amplifier regardless of price.
On the strength of its functionality and good enough performance, I am going to recommend the SMSL RAW-MHA1.
