Pretty similar to my older SMSL DA-9 that also uses Infineon chips.
Some confusion as Infineon has had two series of Class D amps, the Merus MA12070 chips and the MA5332MS chips. Either can be used as stereo or in one chip per channel PBTL mode. While both Merus designs, they are quite different, the MA12070 being filter-less, with little load dependency, but limited to lower output. The DA-9, as well as the Loxjie A30, Sabaj A10a and A20a (black original) use the 12070, as does the Topping PA3s (which along with the a20a use dual chips). The Loxjie A40, SMSL PA40, and Sabaj Silver 2022 A10a and A20a the MA5332MS series. I think all new releases from SMSL including the RAW-MHA1 use the MA5332MS series, but they do not specify.It's mainly the SMSL PA40, but with added XLR inputs.
And of course, they charge you $100 for two XLR inputs.....![]()
Infineon has a GAN series now as well found in some
All, along with the TI TPA325X amps are capable of close to transparent reproduction, so I'm pretty sure the differences I hear are in my head, but my head thinks the MA12070 amps I have heard are indeed warmer, more musical.
