SMSL RAW-MHA1 Stereo Amplifier Review
Rate this stereo amplifier:
    Votes: 20 8.8%
    Votes: 140 61.4%
    Votes: 62 27.2%
    Votes: 6 2.6%
Thanks @amirm
AFAIC : Very poor performance regardless of the price (and 200 bucks with not even some digital input isn't competitive either). The instability within 4Ω clearly is the deal breaker here. I mean... the specs are 160W 4R. What the... ?!
I don't get why SMSL sticks to Infineon when accomplished TPA3255 designs are that affordable these days... :facepalm:
Thanks @amirm
Could this instability be caused by a lack of inductance in the test rig? The older MA12070 chips were known to require 22 µH chokes in a test configuration (mentioned here), in case the amplifier didn't have those on the PCB. Most manufacturers saved a couple of cents and didn't add the inductors to their designs. This amp likely uses MA5332MS, as far as I could find - so a different Infineon chip. Might still suffer from the same flaw, perhaps?
In today's glut of inexpensive, strong performing Class D amps, this is fine but does not distinguish itself in any way. Not too far from its price point are amps with more power and better measurements. But this one will work for a huge amount of consumers, and we know that SMSL is a good brand.
@amirm, you are a very patient human being, but thank you for the review... anyway!
Can another patient-member please explain to me why this device even exists in the flooded, super-competitive, below-$200 market, especially by SMSL who has had a very good reputation for well-received audio hardware?
you can look at SMSL, Topping etc. and realize the product portfolio does not really make sense. it does not need to - they will basically throw everything at the wall and see what sticks. which does not matter anyway because products will EOL in a year and we will have a ver. 2 soon enough.
Something for everyone is basically the product strategy. Each product does not have to make senses, a lot of overlap between their own products but as long as it sells.
It’s a pity to see the level of expectation we’re at these days.
I guess that’s an IA side effect as if it’s hardly working consider yourself an happy customer.
And why not, after all we still have speedometer up to 200km/h even it it’s not allowed everywhere and onto a car than will never be able to reach this speed because…at the end we don’t have to go that fast.
And electric cars have WLTP range because you don’t have to use heater, front light wiper blade and highway to get from point A to point B.
On the strength of its functionality and good enough performance, I am going to recommend the SMSL RAW-MHA1.
Honest conclusion and I'd have no worries buying one given that you said so!
I start to think the same way, but then I wonder as a retired marketer, what the Topping sales, market share, and consumer base is in China, with its population of 1.3 billion. I do not know. But I do know that, for example, that the Chinese middle and upper class are now a massive consumer powerhouse. Far larger than the middle class in the U.S. Perhaps the Chinese EV industry, which is massive, may serve as parallel.
Honest question : did you even read the review at all ?
The amp struggles to provide 33% of the power it claims. 4Ω is not supposed to be a complicated load for any good amp pour there. And people at SMSL are supposed to measure their stuff with an AP...
So something is clearly off here.
I trust Amir, he could have rejected it but didn't because he doesn't tell lies. That's exactly what I want from any reviewer. No lies.
Almost all of them quote the chip maker specs that are this much inflated. They do provide a measurement that shows at the limit, it does spit out more power:
Oops. The concatenated all the measurements together.
I’m a noob but I was thinking that 1% was industry standard isn’t?
Well, that's not what SMSL does usually. They often provide actual AP data of the final product, not theoretical ones from x or y datasheet (both their amps or DAC, for that matter).
That's alright, this is the one to look at :
The DUT is stated as "MDA-1" at 1kHz. So not some random Infineon specsheet. ;)
The speced 160W is at ≈3% THD+N. It should be able to output ≈130W X2 <1%. Which you would agree, your sample failed to do so. My guess is that something is flawed, either their PSU design, or your sample in particular.
