SMSL RAW-MHA1 Stereo Amplifier Review
Rate this stereo amplifier:
    Votes: 20 8.8%
    Votes: 140 61.4%
    Votes: 62 27.2%
    Votes: 6 2.6%
This is a review and detailed measurements of the SMSL RAW-MHA1 balanced stereo amplifier. It was sent to be by Shenzhenaudio and costs US $199.99.
At first I was wondering why the display was not lighting up. But then saw the price and realized the volume control is analog, not rotary digital. Two nicely feeling mechanical switches complete the picture, giving a nice old school feel. You know, no menus, no pushing the knob to turn on the device, etc. Kind of refreshing. Even more refreshing was inclusion of power supply in the case which is a rarity:
As is full size XLR inputs. We even a bridging switch but no trigger or high pass for mains.
The heart of the unit is Infenion class D amplifier and not the common TI choice we see in this class. Let's see how it performs.
SMSL RAW-MHA1 Amplifier Measurements
As usual we start with our dashboard after setting the gain to nominal 25 dB, using the balanced XLR input:
This is respectable output, slightly beating our average for all amplifiers tested to date:
RCA input turns in similar response:
Neither has any mains contributions which is nice.
Noise performance is good for class:
Frequency response shows typical budget class D performance without the output filter being in the feedback loop:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR frequency response Measurement.png
As a result output impedance rises with frequency showing that peaking response.
Crosstalk shows resistive/constant bleeding between channels which I wish was not there:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR channel separation Measurement.png
Multitone test shows nice response where our hearing is most sensitive (2 to 5 kHz)
Again, as is typical, rising distortion at higher frequencies results in somewhat lackluster 19+20 kHz intermodulation results:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR 19 20 kHz intermodulation distortion Measure...png
Company specs, along the lines of its competitors, is highly exaggerated. I could not approach them as I could not get the amp to clip in sweeps:
The amplifier would start to emit high frequency noise, causing the audio analyzer to stop gathering data. Might as well because that is the limit of clean power anyway. You can get a glance of what it can do during short bursts though in our peak power test:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR peak power 4 Measurement.png
The unpredictability didn't let me measure the max power. I did however, manage to capture 40 Hz power:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR power 4 bass 40 Hz Measurement.png
Not that you are going to use this amp to drive full range speakers but you do have good bit of power and more than what I could capture in the sweep at 67 watts/ch.
The Infenion IC amp shows more non-linearities than its competitor:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR power 4 vs frequency distortion Measurement.png
Noise is typical on power up and could be audible:
SMSL RAW-MHA1 Stereo Power Amplifier Balanced XLR power on off noise Measurement.png
Finally, the amp was stable on power up:
There is a ton of competition in the "premium" stereo amplifier budget category. The RAW-MHA1 does not distinguish itself there from pure measurements point of view. But does score strongly in functionality as far as built-in power supply -- a nuances otherwise. And XLR balanced input. Performance is not bad, having scored above average compared to every amplifier regardless of price.
On the strength of its functionality and good enough performance, I am going to recommend the SMSL RAW-MHA1.
out performed by many but okay regardless
I'm 100% ok with amps not having a display. What I don't like is styling designed for a display, but then no display. It's like when you get a stripped down rental car and there's just a swathe of plastic where the screen is supposed to be.
At any rate, while I'm sure it sounds just fine, there's no reason ever to buy this. So I give it a "Not Terrible" and it should consider itself lucky.
Hmm, other than the internal power, it is just functionally good (well sub out is a plus but no 12v trigger/auto sensing). Why getting this over, for example, A5 or much cheaper Mini300?
Yeah nothing to write home about. It performs similar to early TPA-3255 amps. My hope is that Topping comes up with a similar offering or better a RAW-HA1 equivalent.
@amirm, you are a very patient human being, but thank you for the review... anyway!
Can another patient-member please explain to me why this device even exists in the flooded, super-competitive, below-$200 market, especially by SMSL who has had a very good reputation for well-received audio hardware?
I can imagine some prospective customers of the SMSL RAW-MHA1 - who may be unaware of this review - selecting it over the competiton for its built-in power supply unit.
The Loxjie A40 is already a good alternative, the same for the AL400 (Tpa3255 based)
I'd rather get a Topping duo: Mini 300 plus DX1 II DAC
Edit: or even Douk Audio A5 as an amp
At least it has internal power supply, no need for further cheap ugly boxes. However weak, as we can see from 4ohm pwr plot. Those companies are only good in doing DACs and preamps, line level devices. Not in power amps, not in speakers.
I do find it a little surprising that SMSL release these Infineon based amps with 80 or so SINAD and load dependency, yet focus on very high performing DAC's and HPA's.
Thanks for the testing, pic;
JSmith
I'm guessing the protective earth wire is still disconnected internally, thus making the device illegal in the EU? :confused:
The PCB picture above shows all three pins landed. Whether one goes to the chassis, I can't tell.
Pretty similar to my older SMSL DA-9 that also uses Infineon chips.
Works well in a desktop setup and it's very efficient.
Yeah, continuity would need to be tested with a multimeter...
SMSL usually don't connect the ground pin of their power amps for noise reasons, so I wouldn't bet on this one being different...
It's mainly the SMSL PA40, but with added XLR inputs.
And of course, they charge you $100 for two XLR inputs..... :eek:
PA40 measurements here
PA40 VS RAW-MHA1 :
