You can't run EqualizerAPO then (or other EQ software?).ASIO/Wasapi Exclusive playback for Windows.
You can run EQ Software within the playback software that's outputting via ASIO/Wasapi Exclusive. For example, MathAudio Headphone EQ for foobar2000.You can't run EqualizerAPO then (or other EQ software?).
I'll have to look into that. It would be great if I get it running.You can run EQ Software within the playback software that's outputting via ASIO/Wasapi Exclusive. For example, MathAudio Headphone EQ for foobar2000.
That worked a treat, thanks (again) static!That the incoming audio stream from your computer is using a 48kHz sample rate.
That's because macOS and Windows will resample all audio to one uniform sample rate before sending that to your DAC.
You can configure that sample rate in the Midi control panel on Mac and the Sound Control Panel on Windows.
If you'd like that sample rate to adapt to your tracks' native sample rate, them take a look at LosslessSwitcher for Mac or ASIO/Wasapi Exclusive playback for Windows.
A fundamental misunderstanding:Is anyone using the USB-c in? I would love to be able to connect my TV and/or Bluray player. The TV has HDMI out and the Bluray has coax out (with the HDMI out being connected to the TV--no eARC). It seems that converters abound when in reverse (usb to hdmi) but what I need (hdmi or coax to usb) seems rare. And even when one is found, this forum shows that this type of gear can have a wide range of quality. This thing seems close?
I have the SMSL D-6s (the RAW MDA was not yet there) and I want to route all audio (TV, PC, CD) through the WiiM Pro because I want to have room-correction for all audio sources. The WiiM Pro just has one (1) Toslink input, so I was looking for a Toslink switch and found this one:However, I find myself needing one more.
The bright blue LED is nasty
Have you checked the latest manual (Link)?Wondering why the PCM filters on my RAW MDA1 appear to have a different name to those in the instruction leaflet and what I've seen on YouTube videos?
Thanks for the hint - looks like "super bright LEDs" are a frequent annoyance. And I think blue is particularly strenuous for the eyes - but with the name Coolidea they probably had no choice when it came to the color of the LEDs ...
Many thanks.
The most accurate filter is a linear phase filter with fast roll off. Try filter 3 and possibly also filters 2 and 4 for the latest firmware.Many thanks.
And is the concensus to essentially try each one and go with the one that sounds best? Or is there a more scientific approach?
I'm still looking for solutions to solve this on MacOS. Keeping Qobuz up helps a lot at least.hi guys. quick question. are the issues with pops clicks etc, fixed? cheers
Is it only sample rate changes or also when there is a pause between playback?I'm still looking for solutions to solve this on MacOS. Keeping Qobuz up helps a lot at least.
Does anyone know what a white and red 'H' icon on my unit means?
Is there enyone who can compare budget-level DAC like smsl do100 pro or subj with dac of an brandname CD player?
www.audiosciencereview.com
