SMSL R100 DAC Review (NTTY)
I have ordered one here:
Might be some fun, right?
Cool, and if you plan on organizing ABX listening tests, count on me to participate ;)
Simplicity of this approach is appealing, though the practical circuit realization has its caveats. First time I played with such circuits was about the year 1980.
I'd bet, other than the seriously bad clipping over 0dBFS, this is probably not meaningfully distinguishable from any other well designed D/A.
Also this lack of headroom for peaks over 0dBFS would be the reason for true peak limiters becoming common. Modern d/a usually has something like 2dB of headroom beyond FS before things get whacky.
Hi! During quiet passages in the audio, faint clicks can occasionally be heard - sometimes in the left channel, sometimes in the right, and sometimes in the center...
They occur every 3 - 5 - 10 - 20 seconds or so- spontaneously, with no discernible pattern.
They sound like the clicks one might hear from a vinyl record - a nearly new one, at that. The clicks are quiet.
I am listening via S/PDIF; the issue occurs with both optical and coaxial connections. No equalizer is being used.
As a child of the 90's I'd be interested in how early bitstream devices perform by today's standards. The Sonys tested by @NTTY were quite good, how would for instance a DAC 7/TDA1547 compare with current DAC?
But there's a slight problem: Used prices go up. A Philips CD 950 or a Marantz CD 17 is between 400 and 500 € in good condition. The cheapest DAC7-player may be the Kenwood DP-7050 or 7060, mostly below 200 €, if available at all.
Old bitstream [chips] from the late 90s are much better... the TDA1547, and even standard integrated circuits and DACs from JVC, Panasonic, Toshiba, Yamaha, Sony, and Pioneer. Sorry for my own old measurement with Spectralab+ESI Juli@ ADC.
Kenwood DP-5040 default - kopie.pngKenwood DP-5050 Default - kopie.pngKenwood DP-7060 mod AD8066 - kopie.pngKenwood DP-5040 default - kopie.pngKenwood DP-5050 Default - kopie.pngKenwood DP-7060 mod AD8066 - kopie.pngPD-S904-2.pngPD-S702-LME49720.pngPD-M750 default po seřízení optiky.png
R2R Denon DCD-S10 (2xPCM1702J)
...and medium modified low cost Denon DCD-615 with clock,psu and heavy selected AD1860-K,lsb trim = for maximum R2R measurable performance (DF dithering ON). Only for comparing.
"The limitations clearly aren’t coming from SMSL’s processing or analogue stage,.."
Perhaps I've got it wrong, but I was under the impression that the AD1861-J employed its own built-in I/V stage, meaning that SMSL didn't effectively built the DAC's output stage?
AD1861 has both current and voltage outputs, but only single-ended. In R100 you have single-ended and balanced outputs, clear indication that not only on-chip output is used. There is also additional analog filter implemented.
pma​
I’ve written this up with some additional details.
When listening to the R100 R2R, loud clicks can be heard during quieter passages of any recording—sometimes in the left channel, sometimes in the right, and sometimes in the center. It happens randomly.
These clicks occur periodically—every 1, 3, 5, or 10 seconds—in a random pattern.
They sound similar to the clicks heard on a vinyl record, but louder.
The input selected on the R100 makes no difference; the clicks occur regardless of whether I use USB or S/PDIF (optical or coaxial—for instance, via an SMSL PO100 Pro).
I have tried changing everything I possibly could:
- I’ve used various sources, including a PC, a laptop, and a Raspberry Pi.
- I’ve tried different AC power outlets—both grounded and ungrounded.
- I’ve tested with a wide variety of recordings.
Nothing helps.
Important notes:
- The clicks begin 15–30 minutes after the device is powered on.
- If I turn the R100 R2R off and back on again, the clicks disappear—only to return after another 5–10 minutes of listening.
In direct comparisons with my other DACs (SMSL SU-10, SMSL D200), these clicks do not occur, nor have they ever occurred in the past.
I first noticed this while listening to the album *Introitus – 2011 Elements*, specifically on the second track, "02 Earth."
According to an AI, this type of defect could be caused by thermal instability in the R100 R2R’s components, or perhaps a component within the power supply circuit has failed. By the way, if you sniff the connector openings on the rear panel of the R100 R2R, you might notice an unpleasant smell of burnt plastic.
Could you please check yours and see if you notice the same thing?
pma​
Nothing helps.
Important notes:
This seems to me to be a fault. Can you return it?
I absolutely don't need this , yet I kind of want one as a novelty.
I felt that too, but then I thought - no, it's just going to sit there annoying me.
Yeah, what's stopping me currently is I have no practical place to put it. If I get rid of some gear then I'll be in trouble of impulse buying.
I stand corrected then. Thanks for the elucidation.;)
pma​
Nothing helps.
Important notes:
I did not notice such glitches, but I’ll test too.
I have also noticed a similar issue, but only with optical and coaxial input. Not with the USB input. I need to investigate it deeper, a possibility of source drop out, because it seems that the issue has disappeared. I am doing simultaneous recording from outputs of two different DACS, one of them is R100. Same optical S/PDIF input. By now, there are no drop-outs from the R100 channel compared to the S-D DAC output.
