Buy a PS200I wonder what's holding up a review on this? I keep checking, but never anything interesting.
I can assure you that Amir does not have any agenda of the sort.Hi staticV3![]()
I didn't want to make 'false arguments' but I don't think a review of the SMSL PS200 will be done...
... it could 'disturb' DAC manufacturers, including SMSL, so to speak![]()
Hi Zek, latest driver is on SMSL site https://www.smsl-audio.com/portal/product/downlist/id/11.htmlThen where to download the latest original driver?
Your link leads to a list of drivers, so it's not clear which one you tried.Hi Zek, latest driver is on SMSL site https://www.smsl-audio.com/portal/product/downlist/id/11.html
PS 200 is plug and play (no need to install this driver on my Win 10 laptop). However i use a Win 7 or Win 8 laptop for media and above SMSL driver will not load. PS200 will not "start" as per device manager driver window, it seems that it needs usbaudio2.sys however Win 7 and 8 come with usbaudio.sys.
For some reason the SMSL driver package does not load at all on my Win 7 and 8 machines. Just got the DAC, will return to Amazon if its not compatible with Win 7 and 8 and i cannot get it to work.
Thank you StaticV3. I did not notice the Win 7 drivers down on the bottom left of the web page. After installing some win updates the SMSL Win7 drivers did the job. DAC sounds very good and is as i hoped it is an improvement over my 6 year old Sound Blaster DAC.Your link leads to a list of drivers, so it's not clear which one you tried.
Did you try the Win 7 driver?
FYI, there's no reason to mess about with ASIO bridge drivers in modern 64-bit versions of REW.I used FlexASIO diver for both the SMSL and the Cosmos, and I run the E1AD in stereo mode.
Thanks, and indeed nearly the same:FYI, there's no reason to mess about with ASIO bridge drivers in modern 64-bit versions of REW.
Wasapi Exclusive, called "Java EXCL" there, is natively built into REW and provides the same multi-device, bit perfect I/O but with less setup and greater stability.
PS200 is better to SU-1 cause capicitors to +-12 OPA line. Jitter is very poor on USB according to poor clock. Much better SQ is from coaxial from Gustard u18. Also power from linear PS is very important. THD or SINAD is not everything importand. More importnad arę another measures.
Thanks for the measurements. I have this ps200 but I just bought MDA-1 RAW. And I have to say that it plays great on usb. There is no difference between usb and cosxial with Gustard u18. I have many r2r dacs and only this DS sounds nice. I have to try Topping D90 discrete.J-Test as Amir does it (24bits/48kHz input, view 20Hz to 20kHz, linear frequency scale):
He would comment: Text book perfect.
The SMSL is powered by the USB connector: the PC.
Clock is precise beyond requirements for audio, as I mentioned (1ppm).
If anyone wants a specific measurement, just ask.
