SMSL PL200 Review (CD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 1 0.6%
  • Mediocre (**)
    Votes: 1 0.6%
  • Good (***)
    Votes: 17 9.7%
  • Excellent (****)
    Votes: 157 89.2%
NTTY
Reviewer
Switzerland
Hello Everyone,
This is a review and detailed measurements of the SMSL PL200 CD Player and Transport.
It was kindly sent to me by Aoshidaudio.com.
SMSL PL200 - Presentation
Released in 2023 and hosting an AK4499EX, this full aluminum CD player intends to be a high-end one. There a transport only version of the same called PL200T, that adds HDMI and AES/EBU digital outputs, as well as a word clock input for roughly $170 less.
Besides the top loading mechanism, this CD Player offers the below features:
  • High-res DAC from AsahiKASEI with THD+N = -124dB / 0.0000631% / SINAD 124dB
  • 5 selectable filters:
    • Sharp (Default)
    • Slow
    • Short Sharp
    • Short Slow
    • Super Slow (aka NOS)
    • Low Dispersion
  • Four selectable "Sound colors" which I understand allow to change the delta-sigma oversampling rate, and as per my measurements:
    • SC1 (5.6M) : Lowest Distortion, noise shaper kicking off at 30kHz (Default)
    • SC2 (5.6M) : 10dB more distorsion than SC1, noise shaper kicking off at 80kHz
    • SC3 (11M) : 5dB more distortion than SC2, noise shaper kicking off at 110kHz
    • SC4 (11M) : No measurable difference (up to 380kHz) with SC3
  • XLR and RCA outputs
  • Headphones output (on the back, unfortunately), with selectable low and high output
  • Volume control
  • USB input up to 32bit/768kHz, DSD512
  • Bluetooth LDAC (24bit/96kHz), APTX/HD, SBC, AAC
  • It is truly gapless playback (whatever button you touch :p )
The back of the unit is busy, due to the size:
We get big fat Canon XLR outputs, together with unbalanced RCA. We also get two SPDIF digital outputs, one headphones (unbalanced), the Bluetooth antenna and the USB input to use it as a DAC. It requires a socket wall, and I would have loved to be able to use it from an external battery, like the SMSL PL150.
User experience
Similar to the OPPO BDP-95 that I reviewed last week, I thought it's be interesting to share my experience with this device:
  • It can play a CD with the top cover removed provided you press "Play" for 2 seconds.
  • It's obviously very fast at reading the TOC of my 40 tracks test CD (less that 2 seconds as per the above)
  • It will play on the side, which is funny (see below)
  • It's nice to see the disc rotating, really
  • Skipping a track is way faster than most modern players, I like it
  • FFW and REW are fast too, maybe too fast actually
  • The buttons are a bit too narrow for my fingers, but they react well
  • The laser head is noisy when going from the last track to the first one
  • It does not go to sleep mode alone, too bad
Yes, it plays Dark Side Of The Moon gapless ;)
On its side too :cool:
It's nice to see it spinning the silver disc:
The wife experiment
I don't need any measurements, I can tell you that my wife said this player made a massive difference.
How many times have you read something similar(y stupid)? As a matter of facts, when I received the SMSL, my wife was first in line to listen to it, really interested.
And after couple of minutes listening to it, she said "This is crap, it's all well defined, very clean, ok, but no depth, boring as f***". My reaction was... LOL.
But I offered her a little game. I set three devices for comparison, all with headphones:
  • The SMSL PL200, of course, playing from its headphones out
  • My good old Sony CDP-557ESD playing too from the headphones out
  • The Orpheus Zero (need to update that review...), playing through a Rotel Michi P5 preamplifier, headphones out
I adjusted the output and I got lucky to match the three players by 0.04dB max difference. And I asked the wife to select a CD and a track that I would play while she was blinded.
You know the result, right? She said "Ok, I can't recognize them, I'd need more time". My reaction was... LOL.
Enough for the presentation let's go to measurements.
It will be again a long review, and I'm likely to split it in three posts:
  • The standard CD Review
  • The DAC standalone Review
  • A bonus about the multiple filters
SMSL PL200 - Measurements (XLR out)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
All measurements below are with the default "Sharp" filter and "Sound Color : SC1", preamp output set to 0dB, unless otherwise noted.
The SMLS outputs 4Vrms with the preamp output set to 0dB, but the volume knob allows a +1dB, in which case it outputs 4.5Vrms. Output voltage is divided by 2 from the unbalanced outputs.
The two channels are perfectly matched matched at 0.00dB, which is what we should always get from a modern device. Phase was dead flat with default filter (Sharp).
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (XLR out):
Best in class and so close to the OPPO previously mentioned! What you see, besides two little spikes at 2k and 3k (at roughly -125dBr) is what is digitally recorded on the test CD!
Let's try the same at -6dBFS:
Distortion is gone, and similar to the OPPO, I get the feeling to be measuring a digital output, not the analog one. This is perfect result.
I usually have a look at any potential PS related leakage, and you saw it before, there are none, even if I zoom with a punishing 512k FFT length:
The few spikes you see come from the digital file, quantization errors. And, as opposed to the OPPO BDP-95, we don't have low level random noise at the foot of the fundamental. Even if I like to see such good results, I should not get used to that too much, else I'll be disappointed in the future, I'm sure.
Next is the bandwidth:
This is flat within -0.1dB. Note the perfect balance between the two channels, again I like to see that.
And since there are 5 filters, let me overlay all of them (right channel only) and up to 22kHz (Linear Frequency scale, for better viewing):
I've put the plot at 20kHz to ease the analysis. This linear scale facilitates the review, especially of the attenuation. I split all traces on purpose, so don't bother the deviation from 0dB on the left axis.
What we see
  • Sharp and Short Sharp filters are nearly flat beyond 20kHz. The Low Dispersion filter exhibits some ringing and attenuates by roughly -0.8dB.
  • Slow and Short Slow filters attenuate a lot, by -8.5dB at 20kHz! They both are at -1dB as early as 13kHz. This is likely to impact the listening experience of the younger ears.
  • Super Slow filter mimics a Non Oversampling Filter (NOS), so basically no filter, and the attenuation is therefore due to the sinus cardinal enveloppe wrapping the converted data (-3.9dB or so at 20kHz) which is the cause of the zero-hold function of the DAC.
That is a lot of information at once, I'll share more in a subsequent post about the filtering options of this CD Player, because that's really interesting. In the meantime, let me revert to the standard view of the Oversampling default filter (Sharp) with a wider bandwidth:
The filter is fully active at 24kHz (good) and reaches -110dB attenuation which is very good too. The aliases of the two test tones 18kHz and 20kHz are well attenuated below -110dB.
We also see the noise floor rising from 30kHz, and that is an effect of the noise shaper.
Let's have a look at the multitone test that a lot of you like very much, and guess what:
Yes, flawless. It's the best I can expect from that test.
Oh yes, the jitter test:
The best trace I got to date! Even the OPPO was showing a little more. And no, this is not the digital output :p
This is a reference trace :cool:
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
OPPO BDP-95-39dB-28.8dB-19.2dB
OPPO BDP-95 (vol -2dB)-95dB-97.5dB-32.7dB
SMSL PL200-94.8dB-97dB-39.5dB
SMSL PL200 (vol -1dB)-94.8dB-97dB-58.7dB
With the volume set at 0dB (Default), the oversampling interpolator has nearly 2dB headroom. Decreasing the volume by -1dB or -6dB does not change things much, but we still get one of the best resistance to ISO that I've seen. This to appreciate, since many CD Masters are recorded too hot. Well done again to SMSL.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
Woooooooow!!! This again is the best trace I ever reported, even better than what the OPPO achieved! And again, no, this is not the digital output but it so much looks like it!
That means a total absence of noise and distorsion at this theoretical lowest symmetrical level (undithered) of the PCM 16bits.
The ringing is due to the symmetrical reconstruction filter AND the Gibbs Phenomenon (meaning it's normal), else we'd see a square.
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -112.1dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -116.3dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -119.5dB
  • IMD DIN (250Hz & 8kHz 4:1) : -109.2dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -116.7dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -108.6dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -129.7dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -124.5dB
  • Dynamic Range : 98.9dB (without dither @-60dBFS)
  • Crosstalk: 100Hz (below -139dBr), 1kHz (below -139dBr), 10kHz (-125dBr)
  • Pitch Error : 19'997.09Hz (19'997Hz requested) ie -4.5ppm
  • Gapless playback : Yes
The IMD scores are best in class, nearly identical when compared with the boss OPPO BDP-95.
The Dynamic range is the best that can be measured (unweighted) with the Audio CD.
Crosstalk was below what I can measure from the Audio CD at 100Hz and 1kHz, and a crazy low -125dBr at 10kHz. Eat this OPPO :p
Pitch error is a very small -4.5ppm.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I did not overlay with other CD players, because it's the best trace I got, again, and actually it is the same if I run the test from the digital output:
That's the distorsion present on the test CD, nothing else.
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
SMSL PL-20018.7bits100%
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
The PL200 repeats the master class results of the OPPO-BDP95. We are in high-end waters of CD Player here, no doubts!
On repeating requests from the community, I'll add a "de-emphasis test" to verify that this flag is detected and the compliance with the expected de-emphasis curve.
The test is based the same sweep from 20Hz to 20kHz and one has the flag, not the other one.
When the flag is detected, the CD Player should apply the de-emphasis curve and therefore should show the below expected attenuation:
  • 2kHz = -037dB
  • 5kHz = -4.53dB
  • 11khz = -8dB
  • 16kHz = -9.04dB
Here is are the results with the SMSL PL200 which correctly apply the curve with minimum deviation:
These two curves are the same, one has the emphasis flag "ON", that's the only difference. So if the CD Player does not apply the de-emphasis curve, they will overlap. If the CD player decodes the Pre-emphasis flag and applies a correction curve, I can verify the compliance with the expected one.
So I'll include that test in my future reviews, and I might just say that it decodes and provide with you with the measured deviation at 11kHz, I suppose it would be enough.
So my future reviews might just show "De-emphasis compliance (deviation at 11khz) : Yes (0.0dB)"
SMLS PL200 - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)2mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mm1.5mm
Successive dropoutsFrom 2x0.1mm to 2x3mm2.4mm
The above are very good results, although not repeating the excellence of the OPPO BDP-95. That said, the results are unusual for that they vary, while usually I would see a 2mm resistance everywhere. I think this little drawdown is what it takes to be so fast for a modern player. In that area, the OPPO is nothing else but ashamed. Choose your camp.
SMSL PL200 - Digital Output (from Audio CD)
Ok, so it's a perfect CD player. Nothing more can be expected from an external DAC, the internal one being more than best in class for this ancient format. But let's verify if it outputs a "perfect" digital stream. And, from my standard 999.91Hz @0dBFS file...:
Nailed, no artifacts whatsoever.
The 3DC test is nailed too, of course:
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent (by an ASRC for instance), it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go, the below is a comparison between the WAV File directly processed by the PC, and when played by the SMSL PL200 via the optical out:
Same traces = perfect digital output
Partial conclusion (As a CD Player)
I will continue in the next post(s) about the DAC itself with measurements at 24bits and more.
In the meantime, what a CD player! I thought, after the amazingly good results of the OPPO BDP-95 last week, that I would get bored about testing other CD players. And I hoped this one would be a winner with its internal high-end AK DAC. I was not disappointed!
It is very good news that we can buy, today, a master CD Player, true High End, for much less than $1000. And it is more than a CD Player!
The SMSL PL200 sets a precedence nearly everywhere, like the OPPO did last week, even chasing and managing to get ahead in few areas.
And again, like the OPPO, I had the weird feeling to be measuring my test files directly from the WAV source, not from the analog outputs of a CD Player. And I'm addicted to that now!
This is the best available CD Player I had in my hands so far.
Cherry on the cake, and this is a personal note: I know some of you find the top loading an odd thing from the past, but I love that. It makes me interact more with the media that I've been enjoying since 1983 (my 2 first CDs where Michael Jackson - Thriller and David Bowie - Let's Dance). And by the way, yes, I still love to spin a good old low-res record, I have so many. The SMSL makes me enjoy a similar pleasure and it's small enough to fit besides my turn table.
The pleasure to use is way higher than with the OPPO, on my perspective. So that's a big winner that I can only recommend as you would have guessed.
To be continued later...
Phew, that was a long review, and you guessed I enjoyed it. Time has come to check what the AK4499EX is capable of. You might already know, though, but not me ;)
SMSL PL200 - Measurements (as a DAC)
Oddly, I had to install the driver from SMSL for windows to properly recognize it, and then had no issues.
For the tests to come, I tried to align to the best of my knowledge with the way @amirm performs his tests with the AP, not only on the tests themselves, but also on the setup of the analyzer, such as sampling rate, FFT length, averages, low pass filters and weighting curves.
Let's start with the very standard dashboard of the 1kHz test tone at 0dBFS (volume set to 0 on the SMSL, ie 4Vrms output from XLR):
The noise floor is so low that it's nearly below the axis. So we are very close to 20bits free of distortion and noise from a full scale signal! That is a SINAD of 119.6dB. Ok, so I don't own an Audio Precision, just a Cosmos ADC with its scaler companion. But to provide you with some confidence in what I can measure, this is the same measurement from the Topping D50 III that Amir reviewed too:
Amir got 122dB SINAD, I get 124dB with the Topping, meaning 1) I truly measure the PL200 at 119.6dB SINAD, 2) I probably got lucky to have a slightly higher D50 III performer :cool:
On the Dynamic Range side, I got the below:
So, we get a DR of 127.4dB, same as the star Topping D50III, well done!
Multitone performance is very good with very low distortion:
The above is from the WAV file that @amirm shared some time ago and is the multitone test from the Audio Precision. So that helps to compare with the other reviews here.
We have low noise frequency dependent at low frequencies. But the SMSL PL200 ensures distortion free range from 20 to 22.5bits!
The Jitter test shows minimum artifcats:
At -140dBr, they can be ignored, but it would be better not to see them, like with the SMSL D200.
Let's have a look at the linearity:
Straight line down to -120dB, I should have tested lower!
For compatibility with Stereophile measurements, here is the 50 Hz spectra under 640 ohm load (not 600, sorry, I can't), Linear Frequency Scale:
This means very good engineering here as Amir introduced this test after the release of the SMSL PL200, so there was no possibility for them to improve that area.
I will talk about the filters' response in the next post, and I already published filters' response with 44.1kHz sampling rate previously.
Here is the THD+N vs frequency, and sorry I though I measured at 192kHz, but no, I was at 96khz:
I'll redo the trace with 90kHz BW, and you should expect the noise to be a little higher, but anyways that's a very good trace as such. The increase seen at high frequencies is due to the noise shaping with the default "Sound Color" which kicks off at 30kHz.
Partial Conclusion (As a DAC)
In my usual world of CD players, this is more than good, it's from another dimension. This DAC has pushed my ADC to its limits.
What I measured puts it in the "Excellent" category of @amirm, I think it says it all.
That's not all, though, I need to introduce you to the different very interesting DAC settings, and that deserves one last post.
To be continued...
Last, and not least, I wanted to talk about the filtering options of this player, because I think it's really cool.
I mentioned the 5 filters and the 4 "sound" options in the introduction, but I repeat them here:
  • Five selectable filters:
    • Sharp (Default)
    • Slow
    • Short Sharp
    • Short Slow
    • Low Dispersion
The difference between the "Sound Colors" probably refers to the Delta-Sigma modulator oversampling rate. Increasing the oversampling further pushes the noise create by the noise shaper up in frequencies.
So, time has come to look into more details about these 20 total options!
Let's start with the filters. This is a wide bandwidth view of their respective response (with SC1), from white noise:
We see the noise shaper kicking off at 30kHz, and it is common to all filters since this comes from "SC1" option which is the lowest oversampling rate of the Delta-Sigma (my guess).
Look at the blue trace on top of everything, the one that mimics a NOS (Non-OverSampling) DAC. This is a per the books, the standard sample-hold function of a DAC that creates many unwanted artifacts wrapped in a sinus cardinal function. What does that mean? It means that a DAC receives a sample to convert, a binary word to convert to a voltage. It does it and maintains the voltage until the next binary word comes in. The effect of holding the voltage for that short period of time is what creates many artifacts and that sinc envelope. All of that MUST be filtered. When it’s not, you get this:
Sorry, I suck at drawing. The first green section of the left is our converted original 20Hz to 20kHz audio signal (44.1kHz sampling rate). The red section next to it is a mirror copy around 22.05kHz of everything from 20Hz to 20kHz. It is all wrong, and has no meaning. It is the sample-hold effect, it creates unwanted artifacts. And then, there's a copy/paste of that, every times Fs, where Fs = 44.1kHz, it never ends. All of that is wrapped in a sinus cardinal envelope (Orange on the graph).
I'm happy the SMSL PL200 let me play with that. So let's continue and let me overlay to the graph the standard AES IMD 18kHz&20kHz test tones:
Everything I circled in red is wrong, an alias of the original dual tones. This is created by an unfiltered DAC. Look at the very high energy all of this has. If you want to try blowing a tweeter of yours, this is the good way to go!
Ok, now, let's filter properly (Sharp filter), just to see the difference:
Voilà, all the crap is gone with the green graph. It's a sharp filter that removes all unwanted artifacts, copy/paste of what we have from 20Hz to 20kHz, and that's all we need to have in the end.
You might wonder, though, if the crap we saw impacts the audio band. Yes it does:
See the massive amount of distortion (orange, up to -75dB) that comes back into the audio band, as intermodulation distortion. When properly filtered (green) we see nothing.
All of that to say if you want to experience the massive distortion created by NOS DACs, you have one very good opportunity here!
Ok, now let me talk about the "sound color" options. The below graphs are all from the Sharp filter, and from the CD audio (that means 16bits/44.1kHz). Let's start with the first option, SC1, wide bandwidth (up to 380khz) with my standard undithered 999.91Hz test tone at 0dBFS:
We see the noise shaper kicking off as early as 30kHz or so. Let's try the same with "Sound Color 2":
Interesting difference. The dashboard computes a little more distortion in audio band. But we see that the noise shaper kicks off later, roughly at 80khz.
Let's try the same with "Sound Color 3":
The low level noise of the noise shaper comes later again, at around 110kHz. But the computed distortion in audio band is a little higher again.
I spare you SC4 since it's the same as SC3. But what about distortion in audio band? This is better view:
Note this is from the CD, so it's limited to 16bits. We get odd harmonic distortion. That might have a sound indeed, but at such low level?
SMLS PL200 - Final conclusion
Being able to play with different filters and "coloring" the sound with a little more distortion or a massive quantity, is cool, I think. If one wants to test their abilities to hear distorsion at such low levels, you have a winner! This would also help you relax on your needs for high resolution devices.
I think this CD player is really cool.
Wow! I’m interested in this player. There was a bit of negativity when it came out.
Just a note: there is some text referring to the Oppo which is meant to be referring to the SMSL output. Around the digital output section. Let me know if I can give more precise location.
Oopsie, wrong copy/paste, thanks for spotting the mistake! I updated the text. And yes I mention a lot to the OPPO BDP-95 which I reviewed last week, as the reference to best;)
Thanks for the review. Very nice industrial design as well. Too bad about the MQA decal.
Thanks for the review! Nice to see a modern machine putting up class-leading numbers.
I've gone all FLAC, so no mechanical players in my future. But I love the piano-key styling of the transport controls. Reminds me of upscale Japanese portable cassette decks from way back when.
This CDP is the perfect player for all audiophiles who dismiss room EQ (for whatever reason). For those who use room EQ it's a waste.
It is a wonderful CD player with excellent sound. I am not surprised it tests so well. It looks and feels good in use, quiet mechanics while playing. Thank you NTTY for reviewing it. There is a version of the same player with only digital outputs, for a couple of hundred less.
@NTTY:
Look at the headline!
Do you notice anything?
We can't test durability in a short term, but outside that aspect, this is almost textbook perfect for a cd player, with a dac beyond the resolution of the medium itself build in. It's not really cheap, but worht it's 750€ price with that performance if the build quality is solid and durable.
You still get the digital output, but it’s obviously more logical to go PL200T in that case.
