SMSL PL200 MKII Review (CD Player, DAC & HP Amp)
Rate this CD Player
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 4 4.5%
  • Good (***)
    Votes: 13 14.6%
  • Excellent (****)
    Votes: 72 80.9%
NTTY
Reviewer
Switzerland
Hello Everyone,
This is a review and detailed measurements of the SMSL PL200 MKII CD Player, Transport, DAC and HP Amp!
It was kindly sent to me by SMSL and this is the link to the official product page.
SMSL PL200 MKII - Presentation
I already reviewed its predecessor, the SMSL PL200 (which scored very well), and so that is the second iteration.
Released in 2026, and replacing the AK4499EX DAC by an ESS9039Q2M, this full aluminum CD player intends to be a high-end one. As before, it can be used as a DAC, from a computer (USB input) and this MKII version adds a very welcome headphones output (Balanced and SE) at the front of the unit instead of the back (previously and only SE). The headphones out offers a high and low gain choice.
I think the price went a little down, at 600$, so that is good news too.
Talking features, we get again a selection of filters (those of the ESS DAC), and also "Sound Colors". With the SMSL PL200, they corresponded to the delta-sigma oversampling rate. I reported some differences in audio band with added distortion by up to 10dB at the time. With the MKII, it is an offered feature of the ESS DAC whereby it is possible to influence the level of harmonic distortion (H2 and H3), here up to -72dBr! This is similar to what I reported with the SMSL DO400, and I'll talk about it later.
The back of the unit did not change much, but we get a clock input on top:
The Bluetooth antenna is now integrated. All outputs, except the digital one, can be influenced by the volume button, and there is a "DAC mode" to deactivate the Preamplifier. Since the volume is performed in digital domain, activating or deactivating the Preamp mode does not change the measured performances.
I recommend using the Preamp mode, and if you use it as a DAC or CD Player, reduce the volume by 3dB. This will grant you full resistance to intersample overs (see later in the review).
User experience
As with its predecessor, here are is my high level feedback:
  • It can play a CD with the top cover removed provided you press "Play" for 2 seconds.
  • It's very fast at reading the TOC of my 40 tracks test CD
  • It will play on the side, which is funny
  • It's nice to see the disc rotating, really
  • Skipping a track is way faster than most modern players, I like it, and it seems faster and more reactive than the PL200
  • FFW and REW are fast too, maybe too fast actually
  • The laser head appears less noisy than before when going from the last track to the first one, but I can't directly compare since I gave the PL200 to a friend
  • It does not go to sleep mode alone
  • It is Gapless playback
  • It does not apply de-emphasis, since ESS dropped that from their latest DACs, and SMSL told me that they are looking at potential workarounds with ESS
I like the large display and the interface that is super intuitive, as always with SMSL. I also love the fact that I don't need to rely on the remote control for any of the functions.
I will divide this long review into two sections, one dedicated to the CD Player / Transport, and a second one about the DAC and HP Amp.
SMSL PL200 MKII - CD Player Measurements (XLR out)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, the Cosmos APU (for high precision SIAND measurements, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the SMSL PL200 review. It's the same for all my CD Player reviews., so you can compare
All measurements below are with the default "Linear Fast" filter and "Sound Color : Standard", preamp output set to 0dB, unless otherwise noted.
The SMLS outputs 4.281Vrms with the preamp output set to 0dB, from left and right channels, meaning a perfect channel balance. RCA is half of that, again perfect 0.00dB channel balance. The phase is dead flat (Linear Fast filter), and it does not invert polarity.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (XLR out):
Wow, 0 distortion and noise, these are perfect results from a CDA. To be totally convinced, let's overlay that with the original WAV file analyzed in digital domain:
Yep, the exact same. This is as if I was measuring the WAV files I created for testing! It had to happen one day, and here we are. Absolute perfection as a CD Player.
It is the same story at -6dBFS:
The two channels have the same exact performances, and same as from the WAV file. In reality, the PL200 already achieved the same at -6dBFS, but had a little added distorsion at 0dBFS.
I usually have a look at any potential PS related leakage, and you saw it before, there are none, or course, even if I zoom with a punishing 512k FFT length:
Again, this is as if I measured the WAV file. The very little low level spikes are due to quantization (rounding) errors in digital domain. This is a good as it can get.
Let's talk about the various filters. The Linear Fast is the one I recommend since it preserves the bandwidth, offers the best attenuation and is phase flat. but you have multiple choices:
Have a look at the legend to know who's who.
Let me show my preferred one (Linear Fast) with the effective attenuation of dual tones (18kHz+20kHz):
We get more than -110dB attenuation, fully active at 24kHz. You also see there's no visible noise shaping impact up to 80kHz in that view.
Let's have a look at the multitone test that a lot of you like very much, and guess what:
Yeah, perfection for the format, since there is no distortion. The limitation comes from the noise floor, and is due to 16bits quantization.
Oh yes, the jitter test:
Best in class, as the PL200 before it.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
OPPO BDP-95-39dB-28.8dB-19.2dB
OPPO BDP-95 (vol -2dB)-95dB-97.5dB-32.7dB
SMSL PL200-94.8dB-97dB-39.5dB
SMSL PL200 (vol -1dB)-94.8dB-97dB-58.7dB
SMSL PL200 MKII-95.2dB-35.1dB-20.5dB
SMSL PL200 MKII (vol -2.5dB)-95.2dB-95.2dB-95.2dB
With the volume set to 0dB, the oversampling interpolator has 1dB headroom. Decreasing the volume by -2.5dB provides full resistance to ISO. This is to appreciate, since many CD Masters are recorded too hot. Well done again to SMSL. The -95.2dB is the noise limitation from the format.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
The PL200 already achieved perfection on this test, no surprise the MKII repeats it.
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -116.2dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -118.2dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -119.2dB
  • IMD DIN (250Hz & 8kHz 4:1) : -109.6dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -118.1dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -111.0dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -131.0dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -131.7dB
  • Dynamic Range : 98.9dB (without dither @-60dBFS)
  • Crosstalk: below -139dBr at 100Hz, 1kHz and 10kHz
  • Pitch Error (GPSDO corrected) : 19'997.04Hz (19'997Hz requested) ie 2ppm
  • Gapless playback : Yes
The IMD scores are best in class, and a little above the PL200.
The Dynamic range is the best that can be measured (unweighted) with the Audio CD.
Crosstalk was below what I can measure from CDA at all frequencies, wow!
Pitch error is a very small 2ppm, and reduced to 1ppm when using the LeoBornar GPSDO as the source clock.
I like to run a THD (no noise) vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I did not overlay with other CD players, because it's the best trace I got, again, and actually it is the same if I run the test from the digital output:
That's the distorsion on the test file, nothing else, and left and right channels overlay perfectly too.
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
SMSL PL200 MKII18.7bits100%
SMSL PL20018.7bits100%
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
The PL200 MKII repeats the master class results of its predecessor.
SMLS PL200 MKII - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)1.25mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mm1mm
Successive dropoutsFrom 2x0.1mm to 2x3mm1.25mm
The MKII does not repeat the same good results as the PL200. Since the drive appears faster to me, it could explain we lose here to gain there. I'm not really concerned since my daily CD Player is still the good old Sony CDP-557ESD that has same performances, and I can't say I'm suffering from that.
SMSL PL200 MKII - Digital Output (from Audio CD)
Ok, so it's a perfect CD player. Nothing more can be expected from an external DAC, the internal one being more than best in class for this ancient format. But let's verify if it outputs a "perfect" digital stream. And, from my standard 999.91Hz @0dBFS file...:
Yes it is "perfect". Same when performing the good old 3DC test:
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent (by an ASRC for instance), it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go:
We get the over, as expected, no distortion, no added noise, and so meaning perfect digital output on my perspective.
Partial conclusion (As a CD Player)
I will continue in the next post about the DAC itself with measurements at 24bits and more.
In the meantime, and like its predecessor: what a CD player! The MKII managed to perform a little better on measurements to reach the equivalent of analyzing the original WAV files in digital domain. Nothing more can be expected at this stage. Well done SMSL since that creates a precedent.
Only the performances of the drive, in terms of resistance to scratched CD, can be improved. But I must admit I loved the speed of action which improved over the PL200.
More than a high-end CD Player, it it the refence, what we will take for granted at this price point.
And it's not only a CD Player ;)
SMSL PL200 MKII - DAC Measurements
All measurements performed with an E1DA Cosmos ADCiso (grade 0) in mono mode, the Cosmos Scaler (200kohms from balanced input) and APU (when required) for analog outputs. I used a Windows 11 PC to connect via USB and did not have to install a driver.
Unless otherwise notes, all the below are from balanced outputs.
I aligned this review with the one I made of the SMSL DO400, so not all measurements are aligned with those of Amir, as I explained in that review of the SMSL.
Here we start with the standard 1kHz @0dBFS test tone, and output volume set to 4Vrms (48kHz SR, FFT 32k, 4 averages):
The two channels perform exactly the same with a 123.6dB SINAD. When extending the span to the one of Amir (10Hz to 22.4kHz), the SINAD is 123.3dB. Note that left channel has a little more distortion, but all the spikes are below -135dBr, at full scale. Impressive.
The SINAD loses 2dB when using the RCA outputs:
You can see the THD+N of -121.2dB.
Back to XLR outputs, and from experience reviewing CD Players and you saw before, I like to run the same 1khz test 6dB lower:
Again a little more anecdotical distortion in the left channel.
Stereophile was often showing the below and I like it too, so I'm used to reuse it. It is a view from 20Hz to 1kHz with a 1kHz sine at 0dBFS:
As neat as it can be.
Since I'm here, let me add the 50Hz @0dBFS into 600ohms, for compatibility with Stereophile measurements:
Again a little more distortion in left channel, but that is a beautiful trace, from a high performing device.
I already talked about the different filters, so I won't repeat.
Let's talk jitter though (48kHz, 512k FFT. 32 averages):
This is SOTA. The FFT shows 0 side bands, there's absolutely no trace of jitter here. Very nice.
The low frequency "stressor" component of the jitter test can be seen at low frequency, meaning very low noise floor, although not as low as with the SMSL DO400.
Of course, I won't forget the Multitone test (48kHz SR, 256k FFT, 16 averages):
Wow, beautiful again, and much better than the recently reviewed Loxjie D40 Pro. This the proof that not all rely on the DAC chip itself, but the surrounding components that are obviously best in class here.
Next is the THD+N vs Frequency (192kHz, 512k FFT 4 averages, 3PPO (20Hz to 20kHz), 4Vrms output):
This test is hitting the max resolution of the ADC, but less so than the SMSL DO400. As you see from the plot at 1kHz, we get -114.5dB THD+N at 1khz (3.5dB more than the SMSL DO400), with all noise included up to 90kHz. What a performance! The other channel overlays perfectly (noise limited), so I did not include it.
When setting the scaler 6db lower to release the stress on the ADC, it inevitably increases the noise floor relative to the fundamental, and so the measurement becomes identical to that of the SMSL DO400 in that case (-111dB THD+N). This means we truly reach the limits of the analyzer.
Next is the IMD SMPTE vs output level sweep, which can't be compared to the one of Amir because this measurement is based on FFT analysis of IMD distortion only (192kHz, 128k FFT 4 averages, 1dB step, scaler in auto mode):
Ah, finally I have something to talk about! I repeated this test at all sampling rates, and it's always the same story. There is that bump at -45dB, and a little more distortion in the left channel when reaching full scale. That said, we are bellow -100dBr distortion from -30dBFS output, nice.
Dynamic range is where we finally get to see the difference with the higher end ESS9039S of the SMSL DO400 (CCIR-2K weighted an A-Weighted):
That is 6dB less than the SMSL DO400, but still well above the 120dB that we need for transparency.
And now let's have a look at other less usual measurements. The one that I like is the resistance to intersample-overs.
This test is performed with dedicated test tones with a specific phase shift to generate digital overs. If anything in the digital path (oversampling filter / DSP / ASRC) does not have enough headroom for digital overs, it will generate clipping within the interpolator.
For that, I'm using a test tone of 11'025Hz with a phase shift of 45° that goes up to +3.01dB over, by 1dB steps. This allows me to process what's the headroom of the digital interpolator of the DAC. Here are the results (THD+N measurement up to 90kHz):
THD+N 20Hz - 90kHz
Peak = -0.99dBFSPeak = +0.01dBFSPeak = +1.01dBFSPeak = +2.01dBFSPeak = +3.01dBFS
SMSL PL200 MKI (Vol 0dB)-110dB-110dB-43dB-25.8dB-20.4dB
SMSL PL200 MKI (Vol -1dB)-110dB-110dB-110dB-43dB-25.8dB
SMSL PL200 MKII (vol -2.5dB)-110dB-110dB-110dB-110dB-110dB
The above means that at full output power (4.2Vrms from XLR), the interpolator of the SMSL PL200 MKII (Linear Fast filter) has a headroom of just less than 1dB. But because the volume control is done in digital domain, before interpolation, there is more than 3dB headroom when lowering the volume by -2.5dB.
So, with volume set at -2.5dB, you get the best ISO resistance. Like I said in the previous message. The penalty on SINAD is negligible, especially considering how good it is.
Note that the best result (-110dB) is driven by noise, not distortion, and the SMSL DO400 was reaching -115dB of THD+N. This will not change anything to your ears, since we are talking first harmonic at 22kHz, and super low noise + distortion.
I did not repeat the IMD measurements (you have them with the CD Player review), this time including noise, but I lost the excel file I created for that and I don't have the time to recreate it now.
Last and not least, as I did with the Loxjie D40 Pro, I again take the opportunity to revisit the linearity test, since these latest DACs are so good. Here we go:
I'm failing to set the y-axis in dB, and as a consequence to align the result to 0dB. But linearity reaches a staggeringly good -127dB!
SMSL PL200 MKII - Measurements - Headphones
In high gain mode, I got 5.088Vrms with volume set at 0dB into 200kΩ, and 3.44Vrms in low gain mode from the 4.4mm jack. This is not much of a difference between the two.
In low gain mode, 3.44Vrms output, the 1kHz @0dBFS is the below:
In high gain mode, the SINAD (opposite of THD+N) improves:
Now we are at 117dB SINAD.
At 50mVrms output (vol -36.5dB), in low gain mode, I get a little disappointing SNR of 81.8dB:
This is decent for a non-dedicated HP Amp.
SMSL PL200 MKII - DDC Measurements
I forgot to test the DDC functionality and, even if I already verified that it outputs a perfect digital signal from a CDA, let's test if it's the same when used as a Digital to Digital Converter.
Here below is a 997Hz test tone at 0dBFS, 24bits, with dither on the lastvbit, and so that should provide us with a clean signal and 23bits ENOB. And indeed...
...this is what we get.
Complementary test, my good old interesample over test (5512.50Hz @0dBFS with phase shift of 67.5°). That should show a +0.69dBFS over. I player it from Foobar (the file is 16bits):
We get the over and no distortion.
These two quick tests confirm no digital process and we can get a clean digital output to another DAC, from a computer.
Final Conclusion
Not only the SMSL PL200 MKII is a Master Class CD Player, it is also an extremely performant DAC. It is too bad we can't feed it with other sources than a computer, and that leaves room for an MKIII version to SMSL :p
The Headphones output is here for convenience, and offers decent performances, for a CD Player.
I am really happy I got the opportunity to test this very well put together device.
Well done to SMSL, this is the new reference to beat.
Enjoy your WE!
Flo
No doudbt that SMSL company become a major audio electronic player, they master measurements and costs to bri g on market firm products
I would like to see someone writting donw on this company, how they evolved, how they how structured today, how many factories did they build etc etc .. and would love to know more about their R&D teams : what's their road map for the next 5 years
Thank you for review
This is as good as it gets. Again thanks for the thorough review!
How does it compare to the pl200t as a transport? I just got it last week and is contemplating returning it to ger this one.
Anyway, thanks fo the review!
Same, besides less resistance to scratched CDs.
And that makes me realize I did not test the MKII as a DDC interface!
Love to get a review of the SL 200T transport too (echoing the comment for @Ziroz).
The transport has a few more options for output and slightly better specs than the PL200 MkII, at least according to the manufacturer.
Thanks for the great review. I was definitely interested in seeing this one. I get tempted from time to time to have a high end CD player, but I'm streaming my collection so much now it is hard to justify the cost. Here is another temptation though.
No doubt SMSL has become a serious player. They have clearly mastered measurement-based engineering, cost optimization, and bringing technically impressive products to market at very competitive prices.
However, there are still areas where they need improvement. QC appears inconsistent, and software/firmware support is not always at the level expected from a company of this size. Updates are relatively infrequent, sometimes difficult to install, and the documentation or user interface is not always available in proper English.
One area where I hope SMSL will take inspiration is from companies like WiiM, which have set a very high standard for customer support and product evolution, particularly in the moderately priced segment. WiiM has shown that a company does not need to compete only through hardware specifications; long-term value also comes from staying close to users, listening to feedback, and continuously improving products through frequent, meaningful firmware and software updates. This kind of ongoing development can significantly extend the lifespan of a product and build customer confidence. Of course, maintaining this level of support requires additional resources, and those costs will inevitably be reflected in product pricing. However, many customers are willing to pay a little more for better support, reliability and a product that continues to improve long after purchase. It is an approach that would benefit SMSL as it continues to grow.
My own experience with the PL100/PL150 CD players has been disappointing: three units, the first arrived DOA, the second was lost in transit, and the third still has playback issues, with random 3 to 4 second sound dropouts and occasional failure to complete a disc. To their credit, SMSL support did not deny the issue or try to argue that the problem did not exist. However, they also did not offer a practical solution, which leaves the customer with the impression that the attitude is essentially: the issue is acknowledged, but there is nothing to be done.
The choice of slot-loading mechanisms is also a concern. Both the Philips and Fujitsu drives used are discontinued designs, sourced from remaining inventory or reclaimed stock rather than current production. The earlier Philips-based units appeared to be the better choice, but later units using Fujitsu mechanisms seem to have had more reliability issues. Using obsolete transport assemblies in a new product is always a compromise.
On the other hand, I am very happy with my DL200 DAC/headphone amplifier. It is an excellent performer for the price.
So while SMSL deserves credit for its engineering and value proposition, there is still room for improvement in QC, product support and long-term reliability. A detailed look at their history, R&D organization, manufacturing capabilities and future roadmap would certainly be interesting. They are clearly an important company in today’s audio market.
Hello Everyone,
User experience
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
SMSL PL200MKII18.7bits100%
SMSL PL-20018.7bits100%
…Sure but the PrAT is way off.
>> SMSL PL200T Review <<
@NTTY:
Thank you for your time and effort providing those in depth measurements.
An explanation on the purpose of the measurement and what makes a good result would be useful for non experts like me.
Is the distortion introduced by 'too hot' CDs at the DAC stage or is it already too late? I have a CD with nearly +5dB True Peak!
Can you lower the digital output before sending it to an external DAC?
Would it be beneficial when ripping CDs to 'normalize' the WAV file using FFMPEG or SOX before conversion to FLAC (which I am doing now).
Any adverse effect? Any better option?
I am currently using cdparanoia for extraction, rsgain for True Peak measurement and ffmpeg for normalization to -1dB as the standard specifies.
The FOSI Merak could be a good candidate due to its handling of damaged CDs and its ripping feature.
Excellent, though not cheap.
OTOH, many people will spend more for either a player or a DAC alone, so it's relative.
The "dissonant" part for my taste is the red logo on the otherwise clean front.
@NTTY:
Sure, in my signature: More than we hear.
I wrote quite some time ago, and it’d few updates, but it is still good as is.
Like I explained, the volume control of this DAC is before any processing in the interpolator, so reducing the volume by -2.5dB provides a 3dB headroom. If you need 5dB, set the volume to -4.5dB.
No
I don’t know, it all depends on how these tools work and their output. If the end result is a 16bit WAV file, I don’t recommend doing that, as you’d reduce the dynamic range and introduce distortion.
Is this done
But it does not handle hot signals, your main concern.
I suppose SMSL can make a CD-less version of this and add some PEQs and all that jazz.
Great review!
Great review!
A version without CD? Doesn't SMSL already have enough DACs in its lineup?
There are at least eight devices using the ES9039Q2M alone, and over thirty devices in total across all price ranges.
A DSP would only make sense if they sourced the technology externally or hired a capable developer. Otherwise, it will turn into a disaster dragging on for months or even years—just like what happened with Topping, for example.
