SMSL New DP5 SE HIFI Network Music Player only $379
SMSL-Mandy
DP5SE Hi-Fi Network Music Player only $379,and now have the summer sale discount​
Advanced D/A Chip​
Built-in ESS ES9039Q2M D/A chip, the DP5SE boasts a high signal-to-noise ratio and low distortion, providing superior sound quality for all your audio needs.
Supports Multiple Playback Methods​
Supports wired and WiFi connectivity with 2.4GHz and 5GHz WiFi. Stream media playback with DLNA and AirPlay compatibility. Enjoy full-featured playback with support for DSD, WAV, APE, FLAC, AIFF, MP3, and more.
Versatile Connectivity Options​
Whether you prefer wireless, wired NAS, USB flash drives, portable hard disks, PCs, or cell phone USB connections, the DP5SE has you covered. It even supports Bluetooth and DLNA, making it compatible with most playback software.
Full-Featured Interface Output​
The DP5SE offers a variety of output options, including USB, Optical, Coaxial, I2S, AES/EBU, Single-Ended Analog, Balanced Analog, and 6.35mm Headphones. Enjoy full support for MQA hardware decoding, including local playback and USB DAC capabilities.
Supports USB Connection to External Hard Disk​
With support for up to 4TB capacity and NKES/FAT32 format, you can easily expand your music library. The DP5SE also supports Hiby link, allowing you to control its functions using the Hiby player.
Input Modes​
  • Micro SD
  • SAMBA (NAS)
  • OTG1
  • OTG2
  • USB-DAC
  • DLNA
  • AirPlay
  • Bluetooth
Output Modes​
  • RCA
  • XLR
  • Headphone
  • COAXIAL
  • OPTICAL
  • AES/EBU
  • I2S
  • BT
  • USB Audio
Specifications​
  • THD+N: 0.00009%
  • Dynamic Range: 126dB (A-Weighted)
  • SNR: 126dB (A-Weighted)
  • Headphone Output Power: 89mW (32Ω), 64mW (64Ω), 27mW (150Ω), 14mW (300Ω)
  • Unbalanced Line Output Level: 2.1Vrms
  • Balanced Line Output Level: 5.2Vrms
  • Built-in Audio Specifications: Supports up to 32 bit/384 kHz, DSD256
  • USB Output Audio Specifications: Supports up to 32 bit/768 kHz, DSD512
  • USB Audio System Compatibility: Windows 7/8/8.1/10/11; Mac OS X; Linux
  • File System: Supports FAT/FAT32/NTFS
  • Micro SD Card Capacity: Up to 256GB
  • USB Drive/Hard Disk Capacity: Up to 4TB
Additional Features​
  • High signal-to-noise ratio and low distortion
  • Supports wired and WiFi connectivity
  • Full-featured interface output options
  • Supports USB connection to external hard disk up to 4TB
  • HiBy link support for easy control
Advanced D/A Chip​
Input Modes​
  • Micro SD
  • SAMBA (NAS)
  • OTG1
  • OTG2
  • USB-DAC
  • DLNA
  • AirPlay
  • Bluetooth
Output Modes​
  • RCA
  • XLR
  • Headphone
  • COAXIAL
  • OPTICAL
  • AES/EBU
  • I2S
  • BT
  • USB Audio
Specifications​
  • THD+N: 0.00009%
Thank you for the information. Very interesting.
Does the device allow using RCA and XLR simultaneously ?
Or does it have an sub out option ?
Thanks in advance, DT
You can output both RCA and XLR at the same time
but there is no sub out, the power amp have the sub out
Thank you @SMSL-Mandy ,
Very gentle to get these informations confirmed. Unless tests show it differently, the device seems to be a nice option for non-roon users with a preference of local streaming sources.
Could you inform me/us as well, which BT codecs (LDAC, APPX LL etc) are used for incoming / outgoing signal transmission and how many BT connections are possible simultaneously?
I lurked at Head-Fi and noticed your comment on Apple Music ("Apple Music can be entered via usb"), which may indicate that all standard streaming services (Amazon, Spotify, Deezer, Qobuz, Apple, Tidal, IHeart etc) could be used via otg usb - if they support signal transmission through usb output?
As this seems to be a clever workaround (for some), I may conclude that there is no native support for streaming services implemented?
Again, thanks in advance, DT
So if i use an active subwoofer with crossover i can connect it to the RCA outs and the speakers to the XLRs?
Which power Amp would that be?
I am waiting for the day that SMSL merges both HDMI/ARC and LAN connectivity in one-box DAC solution.
Don't get me wrong, @SMSL-Mandy; :oops:
I own both the DP5SE as well as the DO100Pro to achieve both these connections at the current time, which really is a shame and a waste!:(
I cannot make the AES/EUB digital output of my DP5SE work. Anyone can help or comment?
I have just purchased DPS SE streamer mainly for the AES/EUB ouptut to be connected to a pair of my Genelec 8341 speakers. I simply connect the AES output for the DP5SE to the AES input of the speaker using an XLR cable.
However, I do not get any sound? I checked the manual to see if I need to somehow select the AES as output. I can see that I can only select headphone output, which I tested and it works just fine or line out that I have already selected. DId I miss something?
I'd appreciate any inputs from you guys on this. Thanks!
Do you use GLM? @Jrider
Run a measurement/correction with the digital inputs connected. Then see if it works.
I found if you run GLM with only analogue inputs connected, subsequent digital connection didnt work.
Weird as GLM runs via ethernet only!
Thank you for your inputs!
Yes my set up includes a pair of 8341b speakers and their GLM adaptor. I am actually new to Genelec and GLM. So far I have downloaded GLM 5.1 and did the initial setup including assigning a group followed by a correction/calibration. My speaker group shows as "Calibrated" now. I heard the test tones during the calibration, with digital connections, computer >(usb)> SMSL streamer >(xlr)> left 8341 >(xlr) > right 8341 and also the Ethernet connections with GLM adapter and two speakers daisy chained.
So again, test tone works during calibration but there is no sound from speakers when I play music on computer, with the digital and Ethernet connections. The headphone output from SMSL works. But when I select the output to to lineout, the headphone output is cut but nothing from speakers.
I could have missed something very basic, either some settings on SMSL streamer or on Genelec GLM. It has been frustrating. :(
Yeah, maybe have to set AES/EBU output in an smsl menu?
I think that's the reason but I have not figured out a solution yet.
As I mentioned above I only see "HEADPHONE" and "LINEOUT" when selecting outputs for SP5 SE. If I actually connect the analog, "line out"/coaxial outputs of the streamer to the analog inputs of the Genelec using coaxial to XLR cable, the speaker works fine. But I bought the unit for its AES/EBU digital outputs capability.
@SMSL-Mandy : could you help? How to switch the output to digital AES/EBU? I am talking about the "Output Mode" selection in below interface. I only see headphone and lineout. How do I select other formats?
A big bundle of technology in a respectable case with current XMOS and ESS chips and extensive output options, all at a very reasonable price. Regarding the output options the nearest comparisons are the Eversolo DMP-A6 and the Bluesound Node Icon, both at more than double the cost. What is not to like??
Not a lot really, just that Bluetooth 4.0 and not a more recent 5.x implementation is used. Why? - when 5.0 is found in the basic PS200 DAC. The WiiM Ultra has dual ESS9038Q2M chips compared to the DP5SE, which has only a single ESS9039Q2M chip. Perhaps a slightly more generous specification is in order if SMSL delivers a Gen2 version of this potentially great little box.
Does any one who which HiBy app can be used to provide remote control of the S.M.S.L. DP5 SE? Does it work well? If anyone is using it, is it worthwhile, how do you use it.
Thanks.
Thanks.
I assume it's 'Hiby Music' app, the Hiby Link is a feature within the app that allows you to use your phone/tablet as a remote. You can download the app and have a play with it to get a feel for free. I like the app very much, but do not own the streamer.
Hi @SMSL-Mandy, I have interested but I found 4 BUT:
I read from manual 4TB is maximum hard drive accepted through USB, Now I'm using a 24TB RAID for music, are you sure the limit is only 4TB?
Also I read from manual ISO DSD isn't supported like other chinese companies do. Could it change?
Is possible in the near future HFS+ format for hard drive would be included?
Other feature I miss is playback from external USB cd player, it is possible in other chinese products like this.
Started using the DP5se with the HiBy Music app. Here is my experience so far:
The sound of the DP5se is pretty good. For the price, it is a pretty decent DAC.
I am using the HiBy Music app to control it. I have an SSD attached via USB with a variety of music files. The HiBy Music app is not great. It doesn't want to download album art, even thought it is supposed to (and is set to do so). It is not all that intuitive. It could be a lot better. I have also had the app freeze in an iPad Mini.
The biggest problem I am having the DP5se and the HiBy Music app is that it is not recognizing WAV files on the SSD drive. Further, it refuses to play *.aif files, even thought they are supposed to be supported and it sees the files. It responds with "no songs", "song does not support" but the files play just fine directly on my Windows 11 desktop (save is true of the WAV files).
So, if there is a solution to the failure to read certain files, great. But otherwise, this is a problematic device that I would return, if I was still able to.
