SMSL M500 MkII Front Panel Removal
nothinc
Melbourne
A few years ago there was a some talk of disassembling one of these to try adding a heatsink to the ESS ES9038Pro DAC chip, but no one seemed to know how to remove the front (I couldn't find a post about it at least).
Turns out the front glass panel has two extra hex head screws under it. With a hair-dryer and suction cup I was able to remove it. Was pretty straightforward to open up and then reassemble after that.
Just posting here incase anyone is in the same boat!
The idea came from this post, for an
SMSL AD 18 teardown
Thank-you for this important safety tip. The old suction cups and hair dryer trick to remove the glass front panel. Kind of like dissembling an iMac to replace a hard drive. Because it is way cooler than removing the rear of the case with several screws. Much easier to break also. I think some industrial designers need to repair their own designs more often so they stop glueing glass to the case. I can live with a larger bezel. Everything doesn't need to have a seamless case. Focus on correct function.
