Veri
- Joined
- Feb 6, 2018
- Messages
- 9,598
- Likes
- 12,040
Of course no disputing that.I just tell some facts and complaints.
While you are at it, do you have a temperature reading at its best SINAD performance point ?
It would be an interesting point of reference for reference in future investigations.
Sorry you are right, that was Amirs M500. Still seems to be a difference from Retail units and the one Amir got sent.No. My first one is just like this one, and its performance improves as the temperature rises ...
The most probably the differences come from the resistors with lower tempco and/or better capacitors.Sorry you are right, that was Amirs M500. Still seems to be a difference from Retail units and the one Amir got sent.
Lol, I guess we need to do the warm pad mod
It's not just only common in Audiophile gear. I also hear it on other electronic stuff. First time I heard of 'break-in' was purchasing my very first PC ages ago. But I can imagine an audiophile using this thread as reference for "break-in" exists.This might explain the origins of the audiophile 'break-in' myth
I think a remote temperature probe placed on the chip to allow it to warm up to the requisite temperature for best performance point might be good enough ?
https://www.amazon.com/s?k=temperature+probe&crid=3NM5H50VEBK5G&sprefix=termperature+pr,aps,381&ref=nb_sb_ss_sc_1_15
Are you sure about 9038Pro temperature problem ? Maybe it is from another components. The chip 9038Pro will heat in few minutes not in 2 hours. I think the are another fake parts, resistors, capacitors and maybe..... op-amps.
As good a theory as any but yes. Not impossible..?Maybe it is from another components. The chip 9038Pro will heat in few minutes not in 2 hours. I think the are another fake parts, resistors, capacitors and maybe..... op-amps.
@WolfX-700 could you check and the SW and HW version of this new unit? Well, maybe there no golden sample, but (I'm not sure if I reading those past graphs right) it seems this new unit performs better than your friend's unit after warming up, no?
P.S.: I don't know how to thank you. I appreciate a lot your work.
and then rip it to pieces and show us its guts!!SW1.5 HW 1.2
I didn't use warm pad before. And it was very cold that day ...
I'll warm up my friend's one later ... with Warm pad
Don't tube equipment also require this heat-up time before they're at optimum performance levels?It's not just only common in Audiophile gear. I also hear it on other electronic stuff. First time I heard of 'break-in' was purchasing my very first PC ages ago. But I can imagine an audiophile using this thread as reference for "break-in" exists.
