No, its same as it always wasAfter updating to Ver 2.01, was the filter setting divided into two, PCM and MQA, as shown in the attached photo?
Gonna try.
First, standard output is 2V on RCA an 4V on XLR.
Secon, we need a "brickwall at 20kHz", this is a mathematics rule edicted by equations. You can reed a part of the whole story here. The graph shows the how the signal is cut near 20kHz using different filters embedded in the DAC (I mean the silicon, the 9038Pro DAC).
The update worked for me first time I tried, and its been working great. I just ran the xmos installer on the new update (probably didn't need to cause the software didn't really change), it uninstalled the existing xmos and I rebooted and ran the installation again then it got reinstalled, after that I just went ahead with the firmware update.View attachment 58608
USB Firmware was at 1.08 before the update.@osasglo : Hello, what was the usb firmware version of your M500 before you update to 2.01 ?
1.05 ?
1.07 or 1.08?
Thanks for your answer.
I did the update from 1.05 to 1.08 before, mine was on 1.05 when I bought itThank you
Have you already updated from 1.05 to 1.08 before ? Or your M500 was already in 1.08 from the factory ?
I don't really know to be honest, they just include a change log or anything but my unit is performing the best/most stable it ever had since after the update, there might be more variations in the units than we know of. I just wonder if all M500 come with the XMOS XU-216 or if some older ones actually have the XU-208 chip insideI will ask.
Do you know anything about the firmware V2.01 update contents?
V2.01 firmware was erased immediately after being uploaded to HP. I think it was deleted because there was something wrong.
I've contacted SMSL directly, including this, but as usual I don't get any reply.
Please let me know if you know anything.
What is the "issue" with balanced out? Never had any issue on mineHello, I just bought an SMSL and I'm shocked. The balanced output plays almost as well as the unbalanced one. Great product even without sap 9
Version soft 2.01.
View attachment 61001View attachment 61002
