Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
This one compared to D90 and the Sanskrit 10th MKII compared to E30 - the ones tested lately.
On earlier models other things seem to be broken, USB in on Sanskrit 10th MKI and balanced out on SU-8 for example.
I actually had a 10th MKII and, with USB in it sounded perfectly transparent as you´d expect, and worked fine exept for the underwhelming user interface and stubborn remote, but I feel like the measured performance could and should be more consistent. Make them 10$ more expensive, but do some testing before release.
Each brand has these little problems, like the SPDIF input of the Sanskrit 10MKII, the Topping with the problem of the ploc switch versus the DX3 which is rather silent.
Earth terminal and that high voltage connector pushing one each other and there is a risk of it coming out. All that high voltage wires are pressed by the chassis and there is a risk to touch the chassis. The resistance between earth connection and the chassis is 0.1ohm and there isn't any direct clamping screw. If there is short circuit between earth and phase we can have 16A x 16A x 0.1ohm= over 25w on the 10cm of PCB earthe route.
Anyway, I don't care anymore. I notice that no one is interested in details like these. Do as you wish.
Guys, I believe this device will not work if galvanically isolated. I have a motherboard that allows me to turn off usb power to the dac. When I do that the dac disconnects from the computer (or vice versa depending on how you look at it). It says, "no signal detected".
I would really like to still use the feature of the motherboard but it seems it just might be the way the device is made and I'll just have to suck it up (was hoping maybe firmware could change it). It sounds awesome regardless though.
I've asked a couple of people about if it's possible to run the m400 without usb power but haven't really gotten a definitive answer. If it is the case, I'm trying to figure out why. @WolfX-700 said it may be that the usb is only activated if the usb port detects usb vcc power. @JohnYang1997 said he wasn't sure if the d90 also needed usb power to work, it made me wonder if it may have something to do with the ak4499 because most dacs that have their own power supply that I've owned can be run with data only and no usb power.
Correct. A buffer is an amplification stage which doesn't increase the level but reduces impedance in this case. This stage has been eliminated resulting in higher output impedance. It now requires to pay attention to what you hook it up to.
Could a tube buffer like the Yaqin SD-CD3 sort this out? I own and tested Yaqin's SD-CD connected to my amp and with the use of headphones turned the volume all the way up, I then switched the SD-CD3 off and the amount of noise it induces is almost nothing, next to none.
And it has a very wide frequency response making it perfect for Hi Res sources. I use it with my Topping D50 and I love the sound of the combo with NOS (not new production) Tung Sol 6SN7 GTB.
I have some test on the D90, why it is not 122dB as your guys show on the web?
I think your guy is the honest manufacturers before.
I also don‘t like the disingenuous words from manufacturers.
But I've been trying my hardest to try to figure out if the m400 cant have it's usb galvanically isolated. When i cut the usb power to the dac the audio device is no longer recognized by the computer.
Is this expected behavior? No big deal if it is. I just want to know if a firmware update could change it.
That's not what i mean. I've tried to say it a couple different ways but there is definitely a miscommunication going on.
I have the dac plugged into the wall. But usb has power too. Usually with dacs that have their own power supply i disconnect the usb power and only have the usb data going to the dac with no power. I noticed that when powered, the dac still needs usb power for the dac to recognize the usb connection. Im not saying anything disparaging, just trying to figure out if the usb port needs power to work. Like i said i love the dac, im just trying to figure out it's design since i plan on owning it for a long time. I understand the device itself needs power from the outlet but that's delivered through the mains power supply. Im talking about turning usb power off, keeping usb data and having power come only through the wall outlet to the device, i want to cut the usb power too it.
In the end if the dac needs the usb power, im fine with that, since perfomance is amazing regardless.
