MakeMineVinyl
Balanced XLR connections are a carryover from the professional audio world where cable lengths can be hundreds of feet and therefore induced interference into the cable can cause problems. In home applications, there is no need to use a balanced (really differential) connection unless your cabling is picking up hum and noise, which it really won't if its relatively short. The RCA output is typically derived from the balanced output of the DAC chip, and thus there is an additional stage of electronics; this is unlikely to cause anything which would be remotely audible.Thank you for response. And one more question, currently i connected m400 through rca outputs, what the difference in sound between RCA and XLR on this dac? Is it worth to buy klotz cable with neutrik connectors for this unit to connect the headphone amp? amp single ended, but with XLR inputs, Flux FA-12S, XLR sounds better?
In my own system which uses the M400, I run the balanced outputs to the transformer isolated inputs of my preamp simply because my system is very complex (a studio really) and I need the isolation from potential ground loops. I run the unbalanced RCA outputs to my patch bay so I can record on outboard analog tape gear. You're unlikely to run into anything nearly this specialized in your home system. Bottom line - if you have a preamp which has balanced inputs and a couple XLR cables laying around, by all means use them. But I wouldn't spend any extra money to do this otherwise, and I'd recommend just using the RCAs.
