SMSL HO100 Review (Headphone Amp)
Rate this headphone amplifier:
    Votes: 2 1.2%
    Votes: 6 3.5%
  • 3. Fine (happy panther
    Votes: 33 19.3%
    Votes: 130 76.0%
ampguy
US
This looks great, with balanced input. I just wish it had passthrough for use as a preamp in some of the rooms I might move it to. The Topping L50 has this, and I don't mind the increased price ($229 or so), but kind of waiting to see the long term reliability of the L50, as I'm on my 2nd PA5 right now. Any other good HP amps with balanced input, pass through output (balanced is a plus) in the < $300 range with nice remote and display, don't need (or really want) BT.
Nathanael
Does anyone know if there are also somewhere measurements for the unbalanced headphone output? If they are also excellent for all impedances it might be a very good universal headphone amp for 134 Euro (here in Germany).
staticV3
The 4.4mm out on the HO100 is not a "true" Bal out. It's just there for convenience. Performance is identical between both outputs.
plikestechno
How much of this budget stuff with XLR in and outs and 4.4" trrs outputs is truly balanced? Even with non-budget stuff?
Barely any. At a certain point common sense is needed with somebody making this comment in every thread for every product with XLR and 4.4" jacks.
True balanced would mean a transformer at each channel input and output so obviously most of these smaller, cheaper boxes aren't going to be truly balanced. I take more umbrage with 2 and 3k dollar products proclaiming to be balanced when they're not. At that price point, every connection should have a transformer if you are advertising it as balanced.
That said, I don't think staticV3 owns the product. One can't say the performance is identical in real life.
When I first got it, I first tested with a single ended path all the way through. RCA outs on the Topping D90 to RCA ins on the HO100 and 3.5mm jacks. Great until I went to high gain and then it got a bit noisier and I hit it's headroom pretty easily with my HD650s.
Then I tested the same path through the trrs out with my trrs aftermarket cable. Sounded slightly better and I could push the volume better. Is it just a difference with cables? Maybe.
Then I went XLR ins and 3.5 out. Much better noise floor but not much change for headroom. I still wanted to see if the TRRS connection could push things further.
Finally. I went full XLR and TRRS. Sure the path may not be truly balanced but the output was a lot quieter in the noise floor and I could push it much louder. Not just different.
So whether truly balanced or not, using the XLR ins and the 4.4" TRRS out, the supposedly balanced path definitely sounded the best.
So maybe companies should call it grounded or three pin or something to that effect because while it isnt truly balanced having xlr and trrs jacks and an internal grounded power supply does improve the sound.
staticV3
stemag
In Amir's review I see that the HO100 is stable down to 12 ohm.
Will the HO100 be able to drive my 10 ohm Truthear Zero IEM?
What performance can I expect?
_thelaughingman
I used the truthear Zero’s with my HO100 and it’s able to drive them with no problem. You may have to crank up the volume on the low gain a bit.
teashea
Nebraska
Is the front panel plastic or metal? thanks
Wekhrlin
Does anyone with an HO100 have a meter that can measure power consumption? Because I have the following problem: I hear an annoying coil whine when my amplifier is off. It disappears when I turn it on. Since this made me suspicious, I measured the power consumption: When switched on, the amplifier consumes around 5.0/5.2 W. When it's "off", it's 1.5 to 2.2 W, which is significantly more than the <0.5 W that the manufacturer claims.
Wekhrlin
Since it seems to be a defect, I was able to return the unit. The seller was very cooperative (Aoshida Audio via German Amazon).
Dunring
Florida
I just got one and happen to have a meter right behind me to check.
Ide/off 1.5 watt
medium gain 50 percent volume playing 4.9 watt
Wekhrlin
Okay. Thank you for the measurement. The consumption seems to be normal then, even though the manufacturer emphasised to move heaven and earth to make their devices consume less than 0.5 watts in standby. Funny enough, such devices are not allowed to be sold in the EU. Of course, nobody cares. ;-)
LoyK
Ludwigsburg, Germany
My HO100 started to blink red while listening on low volume today...seems like the protection circuit. But there is no mention in the manual how this can be fixed. No sound output anymore. Any idea/chance to fix it without sending it back/repair?
