- Joined
- Aug 5, 2025
- Messages
- 33
- Likes
- 50
Hello ASR members,
We're excited to officially introduce the H400 MK2, our new fully-balanced desktop headphone amplifier designed to redefine precision and performance for headphone enthusiasts and desktop audio users alike.
Every element of the H400 MK2 has been carefully considered: a high-power custom low-noise GaN power supply for clean, stable, and efficient power delivery; a fully balanced discrete component architecture that eliminates common-mode interference and preserves every sonic detail; and a premium op-amp configuration featuring 14 OPA1612A units working in parallel to further reduce noise and enhance dynamic performance. The result is an amplifier that delivers powerful, transparent, and exceptionally precise sound – letting you experience your music exactly as it was meant to be heard.
Whether it’s the subtle details of music or powerful dynamic peaks, the H400 MK2 delivers every nuance to your ears with exceptional purity.
Precision CNC-machined from a single piece of aluminum, the chassis not only delivers a refined metallic finish and premium tactile feel, but also provides exceptional structural rigidity and heat dissipation. The aerospace-grade aluminum alloy offers excellent electromagnetic shielding, effectively isolating external interference and creating a clean working environment for the precision internal circuitry. Every edge and corner is meticulously finished, creating a refined and premium visual aesthetic.
The exceptionally high SNR delivers a dead-quiet background, allowing vocals and instruments to emerge with crystal-clear contours and precise imaging. The immense power reserves provide authoritative control — bass is tight and punchy, while dynamic passages are handled with agility and composure.
The H400 MK2 is not a "colored" or euphonic-sounding amplifier — rather, it functions like a high-resolution window, faithfully reflecting the source and recording without adding its own character. This allows listeners to focus entirely on the artistic expression of the music itself.
For audiophiles seeking a flagship desktop headphone amplifier that offers pure, uncolored sound, immense driving power, and the ability to serve as a long-term "endgame" solution, the SMSL H400 MK2 is undoubtedly a product worth serious consideration.
Colorl: Black,Sliver
For more details, please visit our official website.
https://www.smsl-audio.com/portal/product/detail/id/955.html
Built-in Custom Low-Noise Gallium Nitride (GaN) Power Supply
The H400 MK2 features a specially customized low-noise gallium nitride (GaN) power supply. Compared with traditional linear power supplies, the GaN design delivers higher conversion efficiency and lower switching noise, providing the amplification circuitry with clean, ample, and highly stable power.Key Advantages:
- Low THD: The distortion (THD+N) is as low as 0.00006%, and the SNR is as high as 132dB!
- High Efficiency: Fully balanced discrete component design with massive output power.
- High output power:18W at 16Ω and 9W at 32Ω.
Fully Balanced Discrete Component Architecture
The H400 MK2 adopts a fully balanced discrete component design. Every component is carefully selected and independently optimized, while each signal path is fully symmetrical to minimize interference from the source.Whether it’s the subtle details of music or powerful dynamic peaks, the H400 MK2 delivers every nuance to your ears with exceptional purity.
Fully-Balanced Architecture with 14× OPA1612A Op-Amps
At the heart of the H400 MK2 lies a fully-balanced discrete component amplifier design, incorporating 14 high-end OPA1612A op-amps to form a robust output stage.Amplifier Highlights:
- Fully-Balanced Design: Ensures superior channel separation and noise rejection.
- 14× OPA1612A Op-Amps: Delivers exceptional linearity and low distortion.
- Three Gain Settings: Low / Medium / High for optimal matching with any headphone or IEM.
Ultra-Compact Chassis with Premium Build Quality
The H400 MK2 features an ultra-compact chassis crafted from high-quality aluminum alloy, providing a sleek and modern design that enhances space efficiency.Precision CNC-machined from a single piece of aluminum, the chassis not only delivers a refined metallic finish and premium tactile feel, but also provides exceptional structural rigidity and heat dissipation. The aerospace-grade aluminum alloy offers excellent electromagnetic shielding, effectively isolating external interference and creating a clean working environment for the precision internal circuitry. Every edge and corner is meticulously finished, creating a refined and premium visual aesthetic.
Comprehensive Protection Circuitry
The H400 MK2 is equipped with a full range of protection mechanisms, including DC, over-voltage, and over-load protection. Whether facing unexpected signal surges or improper operation, the protection circuitry responds instantly to safeguard both your headphones and the unit itself. Enjoy your music with complete peace of mind.Inputs and Outputs
Front Panel:
- 4.4mm Balanced Headphone Output
- 6.35mm Single-Ended Headphone Output
- Balanced Headphone Output
- XLR Input
- RCA Input
- XLR Pre-amp Output
- RCA Pre-amp Output
- AC Power Input
Performance Measurements
| Parameter | Measurement Result |
| THD+N | -123dB, 0.00006% (1kHz, 32 Ω) |
| Signal-to-Noise Ratio (SNR) | 132dB |
| Balanced Output Power (16Ω) | 18Wx2 |
| Balanced Output Power (32Ω) | 9Wx2 |
| Balanced Output Power (300Ω) | 1100mWx2 |
| Balanced Output Power (600Ω) | 550mWx2 |
| Unbalanced Output Power (16Ω) | 5Wx2 |
| Unbalanced Output Power (32Ω) | 2.5Wx2 |
| Unbalanced Output Power (300Ω) | 260mWx2 |
| Unbalanced Output Power (600Ω) | 130mWx2 |
Data Proves It – Listening Comforts It
Solid engineering and outstanding measured specifications form the foundation of the H400 MK2. Its sonic signature can be described in three words: accurate, pristine, and effortless.The exceptionally high SNR delivers a dead-quiet background, allowing vocals and instruments to emerge with crystal-clear contours and precise imaging. The immense power reserves provide authoritative control — bass is tight and punchy, while dynamic passages are handled with agility and composure.
33Ω Load – 6.35mm Interface
33Ω Load – Balanced Interface
DNR
SNR
Frequency Response
DNR
SNR
Frequency Response
Conclusion
