SMSL H400
I purchased a couple of SMSL Dac/Headphone amps and thought I'd try some solid state amps for music playback.
I purchased both the H300 and H400 SMSL Headphone amps.
Perhaps I'm used to the sound of my WA22 but I found both the H300 and H400 somewhat flat and boring. I know this is not going to go down well with others opinions on this site but that's my opinion.
I used the following SMSL Dac's with the H300 and H400.
VMV D2R - D300 - DO300EX (Dac/Headamp) - RAW MDA1 (Dac/Headamp) + my Lampizator L4G5 fully balanced.
The following headphones were used.
Hifiman HE1000Se and HE6Se V2, Senn HD800S and Grell OAE1 headphones.
Both the H300 and H400 could drive the notoriously power hungry HE6Se V2 to adequate levels but I never got excited or involved with the music with any of the headphones I listened through.
I could hear the differences between the dac's but my overall impression of the presentation of the music being a bit lifeless and boring remained.
Functionality wise both the H300 and H400 offered all the input and output capability that I needed.
The H400 has the added convenience of remote functionality that I found very useful.
The H300 and H400 offer great features for the money but didn't do it for me.
I've now got a Burson Soloist GT 3 that I'm happy with.
Got it.
I'm actually using my H400 with D90 III discrete* alternating between HD600 and DT880 600 Ohms (both with diy cable for balanced connection). As of now i'm feeling quite happy.
* There's one major problem, i can't put the dac on top of the H400 otherwise statics noises start to join the party, especially on the left output of the D90 (guess it has something to do with electrical interference between the transformer of one unit and some components of the other, but i'm still investigating and trying to find a solution that doesn't imply moving the D90 away from H400...)
Has anyone measured the crosstalk for the H400/SP400 or H300? Or listened for soundstage width differences vs. equivalent Topping offerings?
I see SMSL doesn't publish the crosstalk spec, which is usually not a good sign. (At least Schiit are open about being satisfied with lenient/mediocre NwAvGuy kinds of numbers on this front.)
Solved. I made a new pair of XLR cable in StarQuad config.
If anyone is still having issue with firmware update.
Make sure you choose Unknown Device #1 here. The PDF instructions have this field empty.
Then after it's done installing the driver, then double click the bat file
If everything works like it should, you'll be able to see the update progress instead of the window closing after 2 seconds:
I just kept running the updates over and over again and I got one of them to work. The amp is still an amazing performer. I’m on the waiting list for a Flux Labs………some day.
what features of amp are upgraded with new firmware? @SMSL-Mandy
and also could you provide the steps dB in relay-based volume knob (i assume non-linear)? It makes use of tremendous gain in high gain mode and I do not want to fry anything. Thanks in advance
Susvara needs 25mW to reach 94dB SPL.
HE6se needs 29mW to reach 94 dB SPL.
HE6 needs 31mW to reach 94dB SPL.
Power requirements are blown out of proportion by people with barely functioning hearing, and those that can't figure out how to send 0dBFS Peak to their DAC.
I know this is an old post, but this doesn’t match up with my own experience having owned the HE6SE for several years now…
Correct me if I’m wrong, but THX reference levels require 115dbSPL peak for LFE at the listening position, and that’s not a recommendation for those who are going deaf…
Using the numbers you gave for 94dbSPL, it takes roughly 100X the power (mW) to increase by 20dbSPL. This aligns with my experience, which is that these cans require at least 2-3W of clean power for LF peaks. And they can handle it without distorting…
