SMSL H400 MK2 Preamplifier & HP Amp Review (NTTY)
Rate this Preamp & HPA
  • Terrible (*)
    Votes: 1 1.1%
  • Mediocre (**)
    Votes: 2 2.2%
  • Good (***)
    Votes: 10 11.2%
  • Excellent (****)
    Votes: 76 85.4%
thanks for the review, it's nice to see such a high performing device, but, as French Meloman also says, one doubt remains, why only two inputs?... the scope of a preamp is very often also that of acting as a hub for more sources. I doubt adding more inputs would raise costs dramatically. Then again, being purely analogue, it is to be assumed the digital inputs are all relegated to a dac that preceeds this preamp in the audio chain. Not that dacs have a plethora of inputs though...
I'm a little bit puzzled (but you will excuse me coming from old school hifi) how is this machine supposed to be used? what is its typical place in an audio chain?
In today’s world, the DAC is likely to be the item selecting the source (computer, TV, universal player, …), and the H400 offers headphones amplifiers and high performing volume control. The dual inputs/outputs are only to offer bal/unbal choice, and the variable gain at the output will ease feeding amplifiers with low or high gains.
thought so, but even dacs don't often offer so many additional inputs. Seems like a device with scope confined perhaps in driving one of these nice Purifi final amps.
Balanced 4Vrms output XLR from the DO400 into the H400 Mk2, front balanced output into 200kohms load of the Cosmos scaler, unweighted, were the parameters for that measurement. I can run the same unbalanced indeed.
You may also use the DAC outputs summed as a mono signal. That will increase your DAC SNR by a few dBs.
Straight wire with gain: the gain makes the difference to a simple wire. It means both voltage and current gain, so the output impedance is not related to the input impedance.
Sorry, but no. When in 1975 Peter Walker (aka Quad) coined "a wire with gain" for the Quad 405 amplifier, he was speaking metaphorically about the transfer function—meaning the output voltage is an exact, scaled-up replica of the input voltage (Vout = A x Vin) across the audible frequency band, with zero phase distortion and zero added noise. He was not speaking about current gain.
"An audio power amplifier is required to produce an output signal that differs from the input signal in magnitude only."
Here, the input signal to the power amp is voltage, and so is the output signal.
To be more precise, Peter should have used the term "dependent/controlled voltage source with gain," but then not everyone would readily grasp the meaning.
SMSL high end units do shame the big boys on market in my opinion
I mean, build up todays high end stack SMSL streamer/dac/preamp/power amp N100 + D400 + H400 + PA400 and you good to listen very high end quality
I always use the DAC output as dual mono input in the ADC, if that is what you meant. Summing the outputs of the DAC would not be a real case scenario, but I might have misunderstood what you said.
Same for the Cosmos DM, I use its two inputs in virtual balance mode (with REW), that means 4 selected ESS 9832Pro processing the same signal, to improve SNR of the "analyzer". I showed the difference it can make in that post.
That is with full scale signal. In the case of low level signal, the important element is with the scaler that can increase the gain of the incoming signal to separate the noise of the DUT from the one of the ADC. That’s the reason why I can’t run that measurement at 600ohms input because I need the scaler to helped avoiding the noise of the ADC to mix with the one of the DUT (the scaler offers only 200kohms input in balanced).
I don't see any discrepancy between his and my view.
If the amp has any input impedance less than infinity, the input signal also is current. Same goes for the output signal for any load impedance below infinity. For a wire with gain both currents differ in magnitude only. Nobody says that the magnitude gain needs to be the same for voltage and current.
With their preamp tech, I think SMSL can make more D200 like DAC+Analog preamp models.
We speak about measuring the H400 II's SNR for a 50 mVrms output.
To minimize the impact of the generator's noise in this measurement - in this case your DAC's noise - it makes perfect sense to sum the DAC's 2 output channels into one lower noise single mono channel, IMO.
Also, the typical use case would be to lock the DAC at its nominal level - with no attenuation, so with 5V (or 2.5V) output - and to attenuate the level with the H400 II only.
That's how I'd use them in real life.
This is also where the DAC's own SNR will be maximum.
You explained above that's how you do it - with 4V input, which also makes sense, since it helps standardizing the test conditions, but may add a few tenths of dB of DAC noise. Or not.
You may then measure the H400 II's 50mV SNR of the balanced and unbalanced headphones outputs.
And, as you explain, to lower the ADC's noise impact, you also amplify the H200 II's output signals with a low noise amplifier, like the Cosmos Scaler or APU preamp before the ADC.
What I added is just a suggestion, based on how I measure the same, like here.
And it may still not change the final result.
Basically an active preamp with the noise performance of a passive one—how cool is that?! It’s exactly what I’m looking for. I love passive preamps—or, more accurately, passive attenuators—but the whole impedance-matching game means you end up needing a warehouse full of gear at home just to find components that pair up perfectly from an electrical standpoint… it’s as fun as it is exhausting! ;)
You may still use an E1DA headphones load (you'd then have 300 ohm) or wire a 600 ohm load in parallel with the Scaler's input by using an Y cable.
I don't think that would change the result significantly though.
Ok, got you now, thanks for the time spent sharing.
The DO400 has a SNR of 128dB at 4Vrms output, so we're talking analog volume attenuation only indeed. That's also the reason why I tested again the DO400 and got 84dB in low gain mode, which is what Amir reported too for that one item.
I did not test unbalanced output, and because of the much lower power, it could indeed make a difference, I need to try. I can run the same test as you with the Cosmos load feeding the Scaler as you said, I did not think about doing it this way. I'll give it a try too.
I also bought that Topping L30 II that you mentioned, it's always good to share the same reference. And that's because I forgot I had the A50III :facepalm: that I never reviewed, and I need to play with that one too.
@Rja4000 Thanks again for your feedback, I measured unbalanced headphones output and got a very decent 95.6dB SNR. I did not sum two channels of the DO400 since I don't have the necessary y-splitter. I updated the review accordingly.
As since I did not put in the review, this is the measurement with 5Vrms input from XLR of the DO400, 50mVrms output at the H400 MK2 unbalanced output (volume=31%):
Very good 95.6dB SNR (unweighted), 98dB(A) or 94dB(CCIR-2K) :cool:
What is even better is that this unit now retails for around 250 usd in China right now during the 11/11 sale. Which is, imo, one of the best unit in that price range. I will say its one of the best under 600.
Though in the US we have to pay 430 now during early BF sales because of insane tariffs and shipping costs. I shipped one from china when it came out and it costed me around 350 only lol.
It, imo, cannot drive some high impedance planars comfortably though like he6se(which is notoriusly hard to drive though). The details are still cramped together and the separation is not good. Its definitely loud enough under medium gain though. I do have to crank the volume to the max for low gain. I think it can have a bit more current going in and it would beat even more products in even higher ranges.
Oh hey, look, it's my amp!
I bought this last week to give me some additional headroom over my Massdrop THX AAA 789 with some hard to drive planars I also bought recently. Glad to see it measures as well as SMSL claimed. It's got a ton of power and handles everything I throw at it without working up a sweat.
On sale now at shenzhenaudio.com for $ 452.76…
Hi,
Just to clarify, this is our official SMSL sales link for the H400 MK2:
https://smsl.shop/products/h400mk2?...official-website&utm_term=headphone_amplifier
It's currently on sale for the 11.11 promotion.
If you'd prefer to wait for Amazon's Black Friday deals, you can also find the official Amazon purchase links through our product page:
https://www.smsl-audio.com/portal/product/detail/id/955.html
Thank you for your support!
Thanks for the review @NTTY ! I'm considering the H400 MK2 as a preamp feeding an Audiophonics Hypex NCx252 power amp (26.4dB fixed gain, 1.66V sensitivity).
I see from your measurements that gain affects the pre-output too: low gain at -5.4dB from XLR is perfect for my use case, reducing the attenuation needed from the relay. Your table shows excellent performance out to -30dB.
A question if you don't mind: how many steps does the relay volume have, and what is the step size? I'd be attenuating roughly 50-55dB for low-volume listening (D400 MK2 at fixed 5V XLR, Low gain). Curious how granular the control is at that range, the display shows 0-99% but I can't tell if that's 100 steps or more.
Source would be D400 MK2 at fixed output.
