SMSL H200 Preamplifier & HP Amp Review (NTTY)
Rate this Preamp & HPA
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 2 2.5%
  • Good (***)
    Votes: 8 10.0%
  • Excellent (****)
    Votes: 70 87.5%
Everyone hears differently. Perhaps someday someone will build a device for such measurements.
It’s amusing how you completely dodge the question.
The very reason we’re doing this project is to find out which factors actually make a difference and which don’t.
In 26 years, we haven’t found anything that is audible but not measurable—though that is precisely why we have two measurement technology application developers involved in this project.
Even more interesting is the fact that all other genuine evidence—based on blind tests and measurements—has led to the same conclusion.
But it’s your time and money you’re wasting, as long as you don’t conduct a meaningful comparison.
Chip in the brain. Pay Musk a buck to unlock 24/96 and to skip most ads
That’s not quite right.
The unit uses only 6 or 7 relays for volume control; the rest are for input/output switching.
This type of volume control has been around for over 40 years, and in the 30 years I’ve been using it—and often retrofitting it into other units—I have never seen a relay fail.
For one thing, the low-level signals impose no problematic load or switching voltage/power; for another, the cycle ratings are based on a load of 30V/1A, meaning the actual lifespan is far closer to 50,000,000 switching operations than to 100,000.
Even at 100 operations a day, that would amount to only 1,100,000 operations over 30 years—a negligible number given the light load.
Standard potentiometers wear out much faster and almost always exhibit channel imbalances; it’s more a matter of luck if they don’t.
If a relay were to actually fail, replacing it at a workshop or a repair café would be neither difficult nor expensive.
Like most combined headphone amplifier/preamps, the H200 features dedicated preamp circuitry separate from the headphone circuitry—with distinct paths for the RCA and XLR outputs.
You can tell this by the three additional op-amps for this section and the output impedance of 22/44 ohms for these outputs.
Thanks for taking time in explaining in so much detail.
Speaking of the pre-amp section solely and considering its measurements, is this design 'as good as it can get', or do you know of any other model which has a more competently designed pre-amp (by SMSL, Topping or another brand)?
Could someone explain the purpose of the op-amps visible on the board? SMSL states on the product page that it is a fully balanced discrete headphone amplifier and preamplifier—so what are those op-amps for ( 6 in total)? This one near the output maybe are used for unbal→bal conversion?
Maybe someone from SMSL @Kitty (S.M.S.L Marketing) could comment on this matter.
Basically exactly what op-amps are typically used for in devices like this:
gain stages, buffers, and balancing/unbalancing stages.
Unfortunately, SMSL does not release schematics or more detailed specifications for this sort of thing.
I’m sorry to burst your bubble or shatter any illusions, but there is no such thing as an optimal design—it’s always a compromise.
And optimal for what, exactly?
@NTTY has thoroughly tested the device and published all the key measurements. You’ll need to look at those to decide whether the specs, functionality, and the device itself are optimal for you.
Hello @Kitty (S.M.S.L Marketing)
Since you're already visiting the forum, would you be so kind as to answer my question?
Thanks for your reply. I just wanted your advice whether you know of any device with even less distorting volume control - for controlling DAC's volume.
As for the "bubbles", I would love my remaining ones burst in a proper blind test, should anyone have the facilities for that :-)
If you want something "ultimate," Topping's Pres900 has some great numbers. But H200 seems to be very good for the price. Not sure if one can feel the difference though.
Thanks for the tip! Price and headphone amp apart, does the Pre900 offer any technical advantage as a pre-amp over the Benchmark HPA4? :)
